Hello, everybody, Is there anyone successfully run RGBDSLAM. I carried out on the wiki installation.but i fail. Friend Can you share the successful installation of your success run RGBDSLAM experience it.If you share, please specify your operating environment.There are other things to note...
Originally posted by longzhixi123 on ROS Answers with karma: 78 on 2012-10-18
Comment by yigit on 2012-10-18:
I managed to run successfully on Ros Fuerte, Ubuntu 12.04. You need to be more specific on your problem however, if you are seeking any help.
Comment by longzhixi123 on 2012-10-18:
@yygyt Hello, I want to know you complete the entire RGBDSLAM the complete process.I need to pay attention to what? Reference website is http://www.ros.org/wiki/rgbdslam?
Yes, of course. I can't say anything about paying attention. I mean install and build the package. If you have any problems please state it explicitly. State your system configuration too. Ubuntu, fuerte etc.. Otherwise I won't be able to help.
Comment by longzhixi123 on 2012-10-19:
@yygyt my pc is ubuntu 11.10 64 bit .and i use ROS Fuerte too . and when i type: rosdep install rgbdslam_freiburg i got info :ERROR: Rosdep cannot find all required resources to answer your query Missing resource rgbdslam_freiburg ROS path [0]=/opt/ros/fuerte/share/ros ROS path [1]=/opt/ros/fuert
Comment by yigit on 2012-10-19:
you seen this page? http://answers.ros.org/question/38989/rgbdslam-with-ros-fuerte-installed/
@yygyt i am confused . in the page http://answers.ros.org/question/38989/rgbdslam-with-ros-fuerte-installed/ he said when he type rosdep install rgbdslam . but in the wiki http://www.ros.org/wiki/rgbdslam, there is no such command. just have rosdep install rgbdslam_freiburg. is the wiki changed?
Comment by Felix Endres on 2012-10-21:
rgbdslam_freiburg is the stack, rgbdslam is the package. it shouldn't matter much
Have you seen the command sequence at the bottom of rgbdslam's wiki page? I tried this sequence on a ubunut 11.10 and it worked fine. I'm also running it on ubuntu 12.04. It seems that you downloaded rgbdslam_freiburg into a folder that is not in your ROS_PACKAGE_PATH
I've added a description for how to install ROS Fuerte and RGBDSLAM on Ubuntu from scratch to the wiki page. This was a test of the installation and worked for me without problems. I think it was a 64bit Ubuntu 11.04 or 11.10, so it should work for you. If you are using a 32bit Ubuntu, I cannot guarantee anything, because I have none to test it on. Good luck
Originally posted by Felix Endres with karma: 6468 on 2012-10-24
