I follow the instrutions on http://www.ros.org/wiki/fuerte/Installation/OSX/Homebrew/Source
In the make step, after cmake .. -DCMAKE_INSTALL_PREFIX=/opt/ros/fuerte -DSETUPTOOLS_DEB_LAYOUT=OFF
it stops at [ 60%] Built target test_rosbag_genpy Linking CXX shared library ../../lib/librxtools.dylib Undefined symbols for architecture x86_64: "wxRichTextCtrl::ms_classInfo", referenced from: rxtools::TextboxDialog::onChar(wxKeyEvent&) in rosout_list_control.cpp.o "wxRichTextCtrl::wxRichTextCtrl(wxWindow*, int, wxString const&, wxPoint const&, wxSize const&, long, wxValidator const&, wxString const&)", referenced from: rxtools::TextboxDialog::TextboxDialog(wxWindow*, int, wxString const&, wxPoint const&, wxSize const&, long) in rosout_generated.cpp.o "wxRichTextBuffer::BeginTextColour(wxColour const&)", referenced from: wxRichTextCtrl::BeginTextColour(wxColour const&) in rosout_list_control.cpp.o "wxRichTextBuffer::BeginBold()", referenced from: wxRichTextCtrl::BeginBold() in rosout_list_control.cpp.o ld: symbol(s) not found for architecture x86_64 clang: error: linker command failed with exit code 1 (use -v to see invocation) make[2]: *** [lib/librxtools.dylib] Error 1 make[1]: *** [rx/rxtools/CMakeFiles/rxtools.dir/all] Error 2 make: *** [all] Error 2
All previous steps has been followed without errors. Is there anything I am missing?
Originally posted by jkp on ROS Answers with karma: 43 on 2012-10-16
reinstalling wxPython and using the latest version, instead of the one linked to in the guide solved the problem. This is just a note to others having the same problem.
Originally posted by jkp with karma: 43 on 2012-10-18
Comment by jkp on 2012-10-18:
I can't accept my own answer as the correct answer, becuase my karma is too low. So if anyone with enough karma could close the question, so it won't show in the unanswered list?
