hi. I want to run RGBDSLAM, but encountered a problem.Wiki Page. I've been using the svn to taken out rgbdslam and g2o when I want to compile:rosmake --rosdep-install rgbdslam
Get the error message:Failed to find rosdep libg2o for package rgbdslam on OS:ubuntu version:oneiric [ rosmake ] rosdep install failed: Rosdep install failed 。 My system is ubuntu 11.10 64 bit and i try the website and when i type :rosdep update. i got the info:rosdep: error: Unsupported command update. and the i type :rosdep install rgbdslam_freiburg and i got the info :rosdep install ERROR: failed to install libg2o
Very much hope to your help.Thank you。
Originally posted by longzhixi123 on ROS Answers with karma: 78 on 2012-10-16
In the file manifest.xml, delete the line,
and write,
then try to make it.
I assume that you use ros-electric. If so, you can solve only this error by editing as explained above. If you want to really solve the problem, look into file rosdep.yaml
Originally posted by chris_chris with karma: 84 on 2012-10-16
