Hi! Using template classes with the PluginLib looks interesting. However I've found several problems when I tried it. Firstly the macro PLUGINLIB_DECLARE_CLASS does not look to work with template classes, even using the typical "parameter pareteses for macros" [See Code 1], it finally worked using typedefs [See Code 2]. I would like to automate this mechanism to easily generate plugin classes.
I would like to declare a plugin for each template class instantiation in the code. For that I though two alternatives: - using the PLUGINLIB_DECLARE_CLASS in the class scope -> it didn't worked. The internal pocolib complains about it. - using metaprograming to generate in the root scope all the possible combinations of template class instantiation. Any Idea?(I think PCL do things like that). Finally I think it would be necesary a macro for stringfy a template classname for the 2nd parameter of the PLUGINLIB_DECLARE_CLASS. Any Idea about how to do this?
CODE 1
 #include
 //----- wrong plugin declaration --------
 PLUGINLIB_DECLARE_CLASS(rtcus_navigation, default_ds_twist,
(DefaultStateEstimation<DynamicState2D,Twist2D>),
(StateEstimtion<DynamicState2D,Twist2D>))
CODE 2
//---- working template class plugin declaration -------- typedef StateEstimtion<DynamicState2D,Twist2D> base; typedef DefaultStateEstimation<DynamicState2D,Twist2D> default_ds_twist; PLUGINLIB_DECLARE_CLASS(rtcus_navigation, default_DynamicState2D_Twist2D,default_ds_twist,base) --- [Originally posted](https://answers.ros.org/question/44935/pluginlib-declaring-template-classes/) by [Pablo Iñigo Blasco](https://answers.ros.org/users/356/pablo-iñigo-blasco/) on ROS Answers with karma: 2982 on 2012-10-01 Post score: 1
I have found a partial solution. The plugin-base-class should inherit from an auxiliar-untemplated-base-class. After this you can use a dynamic_pointer_cast to the templated plugin-base-class. This is not bad given the dynamic load is itself dynamic, no additional and unexpected runtime errors should occur. given "NavigationNodeComponent" the auxiliar untemplated base class and state_estimator_name the name of the plugin we want to load.
pluginlib::ClassLoader loader("rtcus_navigation","rtcus_navigation::NavigationNodeComponent");
shared_ptr<StateEstimation<StateType, ActionType, TimeModel> > new_state_estimation =
   dynamic_pointer_cast<rtcus_navigation::StateEstimation<StateType, ActionType, TimeModel> >(
    loader.createInstance(state_estimator_name));
However this is only for the loading stage. How to declare plugin in a more automated way and not manually remains unsolved.
Originally posted by Pablo Iñigo Blasco with karma: 2982 on 2012-10-02
