I'm new at gazebo, and I would like to know how to put a hokuyo sensor on my p2os model. I am not using a real robot, I just want to know how to add a sensor on my simulation. Thanks!
Originally posted by Mendelson on ROS Answers with karma: 73 on 2012-09-27
Comment by allenh1 on 2015-07-07:
Are you using P2OS or are you using ROSARIA?
Or just create a laser link and add something similar to this:
  <link name="laser_scan_link" type="laser">
 <inertial>
      <mass value="0.5" />
      <origin xyz="0 0 0" />
      <inertia ixx="0.3"  ixy="0.3"  ixz="0.3" iyy="0.3"  iyz="0.3"  izz="0.3" />
     </inertial>
     <visual>
       <origin xyz="0 0 0" rpy="0 0 0"/>
       <geometry>
         <cylinder length="0.1" radius="0.05" />
       </geometry>
     </visual>
     <collision>
       <geometry>
       </geometry>
     </collision>
  </link>
<joint name="laser_to_base_link" type="fixed">
  <origin xyz="0.25 0 0.32" rpy="0 0 0" />
  <parent link="base_link" />
  <child link="laser_scan_link"/>
</joint>
   <gazebo reference="laser_scan_link">
  <sensor:ray name="laser_scan_link">
     <rayCount>683</rayCount>
     <rangeCount>683</rangeCount>
     <laserCount>1</laserCount>
         <origin>0.0 0.0 0.0</origin>
         <displayRays>true</displayRays>
         <minAngle>-105</minAngle>
         <maxAngle>105</maxAngle>
         <minRange>0.06</minRange>
         <maxRange>4.0</maxRange>
         <resRange>0.01</resRange>
         <updateRate>10.0</updateRate>
         <controller:gazebo_ros_laser name="gazebo_ros_base_scan_link_controller" plugin="libgazebo_ros_laser.so">
                <gaussianNoise>0.005</gaussianNoise>
                <alwaysOn>true</alwaysOn>
                <updateRate>20.0</updateRate>
                <topicName>base_scan/scan</topicName>
                <frameName>laser_scan_link</frameName>
                <interface:laser name="gazebo_ros_base_scan_link_iface"/>
         </controller:gazebo_ros_laser>
        </sensor:ray>
    </gazebo>
  <gazebo>
   <controller:gazebo_ros_controller_manager name="gazebo_ros_controller_manager" plugin="libgazebo_ros_controller_manager.so">
      <updateRate>1000.0</updateRate>
      <interface:audio name="gazebo_ros_controller_manager_dummy_iface" />
    </controller:gazebo_ros_controller_manager>
  </gazebo>
Originally posted by Peter Listov with karma: 338 on 2012-09-29
Comment by Vegeta on 2012-10-18:
@Peter Listov I got interested with this answer, can you give a suggestion into how to add a hokuyo laser to the turtlebot. I am new to ros. Can you tell me where do I have to put the code.
For this you will first need to understand how urdf works and John has written great tutorials for that http://ros.org/wiki/urdf/Tutorials (section 1 and 2). Then you will need to understand the Gazebo extensions for URDF (http://ros.org/wiki/urdf/Tutorials/UnderstandingPR2URDFGazeboExtension) and finally here is also an example of how to add the actual sensor: http://ros.org/wiki/urdf/Tutorials/AddingSensorsToPR2.
For the insertion of the hokuyo specifically you can check how it is being done for turtlebot: Sensor description: https://kforge.ros.org/turtlebot/turtlebot/file/fb8354a98ac5/turtlebot_description/urdf/gazebo.urdf.xacro (turtlebot_sim_laser) Sensor insertion into robot's urdf: https://kforge.ros.org/turtlebot/turtlebot/file/fb8354a98ac5/turtlebot_description/urdf/turtlebot_body.urdf.xacro (laser_joint)
Please also note that this shall probably be asked on http://answers.gazebosim.org/questions/.
D.
Originally posted by dejanpan with karma: 1420 on 2012-09-27
