I want to run RGBDSLAM, on the site of introduction 64bit ubuntu 11.10.But my machine can only install 32bit of ubuntu 11.10, Can not tried it?link text
Originally posted by longzhixi123 on ROS Answers with karma: 78 on 2012-09-25
Comment by Felix Endres on 2012-11-15:
So, does it work now?
Comment by longzhixi123 on 2012-11-18:
thanks Felix Endres, i have make the rgbdslam package ok with http://www.ros.org/wiki/rgbdslam ,and pc is 64 bit , not 32 bit .
Although that page appears to say you can only run on a 64-bit Oneiric system, I suspect it really only means that the developers used that system for testing. It should work on other versions and platforms.
Why don't you try it on your 32-bit machine and see?
If it does not work, please edit your question, explaining what you tried and what happened.
Originally posted by joq with karma: 25443 on 2012-09-26
