Hi everyone
I am new to ROS and Gazebo and I got problems into using the joint_state_publisher package. I have a robot with multiple non-fixed joints. I created 2 launch files : one to display the robot in rviz, the other to display in Gazebo.
RVIZ :
    <launch>
    <arg name="model" />
    <arg name="gui" default="False" />
    <param name="robot_description" textfile="$(arg model)" />
    <param name="use_gui" value="$(arg gui)"/>
    <node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" ></node>
    <node name="robot_state_publisher" pkg="robot_state_publisher" type="state_publisher" />
    <node name="rviz" pkg="rviz" type="rviz" args="-d $(find urdf_tutorial)/urdf.vcg" />
</launch>
Gazebo:
<launch>
<include file="$(find gazebo_worlds)/launch/empty_world.launch"/>
<arg name="model"/>
<node name="spawn_emox" pkg="gazebo" type="spawn_model" args="-urdf -param robot_description -z 5 -model emox" respawn="false" output="screen"/>
</node>
</launch>
By setting the "gui" argument to "true", I can control the joints on rviz via the joint_state_publisher, but this doesn't work on Gazebo.
Using rxgraph, I see something like that :
/joint_state_publisher---> /robot_state_publisher ---> /rviz ---> /rosout
/gazebo ---> /joint_state_publisher---> /robot_state_publisher ---> /rosout
Actually, /gazebo publishes a /clock topic to both joint_state_publisher and robot_state_publisher, whereas /rviz subscribes to the /tf topic (as expected).
Does anyone know if gazebo can be set as a /tf subscriber? Or any other solution to control the robot in gazebo? Would the pr2_mechanism stack be adapted?
Sorry about the beginner question and the poor english.
thanks!
Originally posted by arzhed on ROS Answers with karma: 143 on 2012-09-24
Comment by arzhed on 2012-09-24:
Thank you very much for the quick clear answer!
RViz is just visualizing your robot while Gazebo is a complete simulation environment that simulates a complete robot, including its joints and the motors connected to them.
In case of rviz, running the joint_state_publisher node creates a publisher on the joint_states topic. The robot_state_publisher then subscribes to that topic and publishes the corresponding TF tree.
In gazebo you must not run the joint_state_publisher. Instead, you need to run controller plugin (e.g. the gazebo_ros_controller_manager) that reads the joint states from the simulated robot and publishes them on the joint_states topic. You cannot move the robot by just publishing different joint states since joint states represent the current state of the robot, not a goal. Instead you need to run controllers that apply forces at the simulated joints.
Originally posted by Lorenz with karma: 22731 on 2012-09-24
Post score: 8
Comment by zisikons on 2016-07-18:
You probably mean the robot_state_publisher subscribes to /joint_states topic and publishes the corresponding TF tree.
