I use ROS electric.
I followed Object Recognition Kitchen.
This doc says 'Install the ros-electric-object-recognition package from the official ROS repositories.'
I try to install:
  sam@/home/sam$ sudo apt-get install ros-electric-object-recognition
  Reading package lists... Done
  Building dependency tree
  E: Unable to locate package ros-electric-object-recognition
  sam@/home/sam$
How to fix it?
Thank you~
ROS apt:
  sam@/etc/apt/sources.list.d$ cat ros-latest.list
  # deb http://packages.ros.org/ros/ubuntu natty main # 停用升級至 natty
  sam@/etc/apt/sources.list.d$ cat ros-latest.list.distUpgrade
  deb http://packages.ros.org/ros/ubuntu maverick main
  sam@/etc/apt/sources.list.d$ cat ros-latest.list.save
Originally posted by sam on ROS Answers with karma: 2570 on 2012-09-14
For me, the package exists in electric. I can also see it at packages.ros.org.
Maybe you need to run sudo apt-get update first? Otherwise, what is your apt entry for ROS?
Originally posted by dornhege with karma: 31395 on 2012-09-14
Comment by sam on 2012-09-14:
I try to use apt-get update but doesn't work. I have updated my original post. What to do next? Thank you~
Comment by dornhege on 2012-09-14:
The ros repository in ros-latest.list is commented out. This obviously won't work, just remove the #, run apt-get update again and it should work.
Note: This automatically happened during the maverick -> natty update. You should have gotten a warning about that from ubuntu and it will probably happen on every ubuntu update again.
