Hi All,
I have to simulate a planning environment where objects whose poses are randomly determined are added.
It is obvious to check if the just-added object is in collision with the robot, as in here.
How to check if it is in collision with the other existing objects?
Thanks a lot.
Originally posted by tor on ROS Answers with karma: 277 on 2012-09-13
you need this method:
bool isObjectInCollision(const std::string& object_name);
it's a public method of planning_environment::CollisionModels.
besides, if you want to know exactly which objects are in collision with the target object, use this method:
void getAllEnvironmentCollisionsForObject(const std::string& object_name,
                        std::vector<arm_navigation_msgs::ContactInformation>& contacts,
                        unsigned int num_per_pair = 1);
Originally posted by yangyangcv with karma: 741 on 2012-11-01
Comment by tor on 2012-11-05:
Please note that the goal is to check whether an object is in collision with another object, not with a robot. AFAIK, your answer works for the latter. Anyway, thanks.
Comment by yangyangcv on 2012-11-05:
i don't agree with you. getAllEnvironmentCollisionsForObject() will return all the collisions for the specified object, no matter it is a robot link, or another object. you can check the src of this method.
Comment by tor on 2012-11-08:
Well, to call isObjectInCollision(), we need an instance of CollisionModel whose constructor needs a robot description. Therefore, even if we have the object cm from rbt_desc, cm.isObjectInCollision("obj") will tell whether "obj" is in collision with the rbt_desc's robot. CMIIW.
Comment by yangyangcv on 2012-11-09:
well, i have not test the function isObjectInCollision(), but i do test the function getAllEnvironmentCollisionsForObject() and it does work. and of course, you need an instance of CollisionModel.
