I run this command: rosrun release create.py wu_ros_tools 0.1.0 electric using the electric version of the release script.
The stack file I'm using is here in my repository.
However, after the above command checks out the repo, I get this error.
ERROR: Stack's declared dependencies are missing calculated dependencies:
geometry
visualization
diagnostics_monitors
common_msgs
...but I DID declare those stacks, didn't I?
Originally posted by David Lu on ROS Answers with karma: 10932 on 2012-09-13
Might there be local changes in your working copy?
Originally posted by tfoote with karma: 58457 on 2012-09-14
Comment by David Lu on 2012-09-16:
Must've just de-synched. Works now.
