Hi everybody, I use gscam (http://www.ros.org/wiki/gscam) to generate a video stream and mono_odometer application of viso2_ros (http://www.ros.org/wiki/viso2_ros#) to process it and compute visual odometry. Giving a look at the odometry messages I get the following info:
aldo@aldo-ubuntu:~/Projects/4thRC/BergamoComponents/services_caller/bin$ rostopic echo /mono_odometer/odometry
header:
  seq: 7
  stamp:
    secs: 0
    nsecs: 0
  frame_id: /odom
child_frame_id: /base_link
pose:
  pose:
    position:
      x: 0.0358117049907
      y: -0.105056291215
      z: 1.05073866966
    orientation:
      x: 9.03653364967e-05
      y: -0.000380259093953
      z: -0.000498042565549
      w: 0.999999799595
  covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
twist:
  twist:
    linear:
      x: 0.0
      y: 0.0
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: 0.0
header:
  seq: 8
  stamp:
    secs: 0
    nsecs: 0
  frame_id: /odom
pose:
  pose:
    position:
      x: 0.0409528148301
      y: -0.116839589994
      z: 1.17038278247
    orientation:
      x: 0.000299344860283
      y: -0.000918266853756
      z: -0.000664260264014
      w: 0.999999312968
twist:
  twist:
    linear:
      x: 0.0
      y: 0.0
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: 0.0
As you can see odometry info (position and orientation) are updated properly, but timestamp (secs and nsecs) are never updated. I think rviz can't show me the robot odometry or position for that issue, but I'm not sure. Can anybody help me? Regards
Originally posted by aldo85ita on ROS Answers with karma: 252 on 2012-09-11
Comment by axp'dc on 2020-10-17:
Hi there. I was wondering if you could explain how you got the odometry data to publish when running. I am trying to get images from a rosbag and i am using a launch file to remap topics. When I run rostopic echo /mono_odometer/odometry, nothing appears.
I fixed it! Use the patch described at :
http://toychest.in.tum.de/wiki/_media/fastdev:gscam.patch
in particularly, add the following instructions in src/gscam.cpp:
ros::Time now = ros::Time::now();
msg.header.stamp.sec = now.sec;
msg.header.stamp.nsec = now.nsec;
camera_info.header.frame_id = frame_id;
camera_info.header.stamp.sec = now.sec;
camera_info.header.stamp.nsec = now.nsec;
Bye
Originally posted by aldo85ita with karma: 252 on 2012-09-13
