Hi All,
Is there a way to set verbosity/logger levels programmatically (up to node levels if possible)? How?
I have looked at here and here. It seems that I should somehow use log4cxx::Logger, cmiiw, but still do not know exactly how? Please help.
Thanks a lot. PS: Hopefully, for both roscpp and rospy (+roslisp)
Originally posted by tor on ROS Answers with karma: 277 on 2012-09-07
Post score: 5
Comment by Rufus on 2020-05-17:
Related: https://answers.ros.org/question/197964/set-log-level-in-launch-file/?answer=350817#post-id-350817
3 Answers 3
Or simply add
 if( ros::console::set_logger_level(ROSCONSOLE_DEFAULT_NAME, ros::console::levels::Debug) )
    ros::console::notifyLoggerLevelsChanged();
in your nodes constructor. Replace Debug with your required logger level.
Don't forget to
#include <ros/console.h>
Originally posted by hvpandya with karma: 76 on 2015-11-20
I do this quite often when writing new nodes in C++. Usually what I do is place the following little snippet right after my call to ros::init
log4cxx::LoggerPtr my_logger =
           log4cxx::Logger::getLogger(ROSCONSOLE_DEFAULT_NAME);
my_logger->setLevel(
           ros::console::g_level_lookup[ros::console::levels::Debug]);
This will set the node's log level to Debug. Then I comment it out after the node is sufficiently developed. I have never really looked into doing this in rospy or roslisp, but would also be interested in figuring out how.
EDIT
I just realized that this is quite easy to do with rospy as well. As documented here, you can simply pass the log_level argument to a call to rospy.init_node() e.g.
rospy.init_node('my_node', log_level=rospy.DEBUG)
Originally posted by jarvisschultz with karma: 9031 on 2012-09-08
Comment by Lorenz on 2012-09-10:
For completeness: in roslisp you have the method set-debug-level to set the level of a specific logger.
Comment by Dirk Thomas on 2014-01-14:
You should not use g_level_lookup to map the ROS debug level to the log4cxx log level. Instead use the log4cxx level directly. Besides the package must specify a dependency on log4cxx in its package manifest and the cpp file must include the necessary log4cxx header(s).
For anybody stumbling upon this page, if you just want to set verbosity of packages as soon as they are launched by launchfiles, the easiest way is:
  1. to export ROSCONSOLE_CONFIG_FILE="/path/to/my/config/rosconsole.config"
  2. edit, for example with vi /path/to/my/config/rosconsole.config adding these lines:
log4j.logger.ros=INFO
log4j.logger.ros.roscpp.superdebug=WARN
log4j.logger.ros.my_package_name=DEBUG
  1. launch your launchfile in the same shell.
The package name must be the one who corresponds to <node pkg="my_package_name" ...> line in the launchfile.
Post score: 4
