Greetings,
First, I apologize for not knowing how to format my code nicely, but it compiles and runs, so I know I don't have programmatic errors.
I have a turtlebot using binocular cameras. I am using two nodes to control the system, one has the locomotion/path planning the other deals with image processing.
I am using the client to request information from the image capture, which is supplied by the service. Inside the service I am using class methods to define my callbacks.
Using ros::spin(), once the service calls "bool grab", the subscription for images from the cameras spin indefinitely. I would like the ability to spin the service indefinitely, but force the camera images to be grabbed once and processed. then if i need new images, I will request them from the client and grab two more, without spinning indefinitely.
I think I can do this using separate queues, one for each camera stream, and a the master one for the service, but I don't think that will actually function the way I described.
Note* I have removed most of the guts from the camera callback to simplify what I have posted, because it would have been unnecessary.
class ImageGrab
private:
ros::NodeHandle nh_;
image_transport::ImageTransport it_;
image_transport::Publisher image_pub_;
image_transport::Subscriber image_subr_;
image_transport::Subscriber image_subl_;
ros::ServiceServer grab_service_;
public:
long int p_x1r, p_x2r;
ImageGrab()
: it_(nh_)
grab_service_ = nh_.advertiseService("/obj_31/Image_Grab", &ImageGrab::grab, this);
~ImageGrab()
cv::destroyWindow(WINDOW);
bool grab(obj_31::Pixels::Request &req, obj_31::Pixels::Response &res )
ROS_INFO("entered bool grab");
image_subr_ = it_.subscribe("/right/camera/image_raw", 1, &ImageGrab::imageCbr, this);
image_subl_ = it_.subscribe("/left/camera/image_raw", 1, &ImageGrab::imageCbl, this);
res.x1r = p_x1r;
res.x2r = p_x2r;
return true;
void imageCbr(const sensor_msgs::ImageConstPtr& msg)
p_x1r = 20;
void imageCbl(const sensor_msgs::ImageConstPtr& msg)
p_x2r = -56;
} // close ImageGrab class
ros::init(argc, argv, "test_server");
ImageGrab ig;
ros::spin();
return 0;
Originally posted by benjaminabruzzo on ROS Answers with karma: 45 on 2012-09-03
