I've been going through Syskit tutorials at rock-robotics.org. In the tutorials e.g. First composition, there are two different components declared with:
add Controldev::JoystickTask, :as => "cmd"
add RockTutorial::RockTutorialControl, :as => "rock"
I was wondering how could I add an additional RockTutorialControl
into the composition, so that the instantiation would then create two separate instances of the same component?
I've tried something like
add RockTutorial::RockTutorialControl, :as => "foo"
but this apparently isn't the way to go. syskit instanciate
command shows only one instance of RockTutorialControl, but gives two roles to it (rock and foo). What is the meaning of "role" in this context?
I've noticed that the tutorial explains how to make multiple instances of the same component when we're declaring our components as Devices. But how to do this with components that should not be concerned as devices?
BR, Mathias
EDIT:
This was my first question to StackExchange, and I don't know what's the policy for adding additional information to the original question, but here we go:
It seems that both the deployment and configuration need to be different when there are two instances of the same component. I did a small scale testing with two components:
using_task_library 'foobar_user'
using_task_library 'foobar_proxy'
module FooModule
class FooControl < Syskit::Composition
add FoobarUser::Task, :as => "producer"
add FoobarProxy::Task, :as => "proxy"
add FoobarUser::Task, :as => "consumer"
producer_child.connect_to proxy_child
proxy_child.connect_to consumer_child
end
end
where FoobarUser::Task
has an input & output port of /std/string. FoobarProxy::Task
has corresponding i&o ports. FoobarUser::Task
has also two configurations called 'default' and 'other'. It also has two deployments 'foo_depl' and 'bar_depl'.
In order to create a "pipeline" where data flows producer ==> proxy ==> consumer, I made define line:
define 'conf_and_depl', FooModule::FooControl.use('producer' => FoobarUser::Task.use_conf('other').prefer_deployed_tasks(/foo_depl/), 'consumer' => FoobarUser::Task.use_conf('default').prefer_deployed_tasks(/bar_depl/))
and then instanciated the network with
syskit instanciate scripts/03-nwtest.rb conf_and_depl_def!
The component instanciation failed if either use_conf
or prefer_deployed_tasks
clause was left out. In both cases the produced error was "cannot deploy the following tasks... ...multiple possible deployments, choose one with #prefer_deployed_tasks".
