-------------------- SOLUTION ----------------- message_filters::TimeSynchronizer... has to be message_filters::Synchronizer... found that out after a day
How to mark as solved ?
Hi
I want to synchronize the image_color and the depth/image topic of a kinect.
both topics have different frequencies. i hoped before that they publish at the same time but sadly not.
is there a way to let these to topics been published simultaneously?
other posibility is to use a topic with rgb and d info, but i need an easy way to get the opencv rgb image.
the only topic i see, which has all info is "depth/points", but I need an opencv RGB image also, an iterative loop over the pointcloud to obtain the opencv image pixel by pixel seems to be studpi, because rgb image topic already exists.
why doesn'T that work:
private:
    message_filters::Subscriber image_sub;
    message_filters::Subscriber pointcloud_sub;
    message_filters::TimeSynchronizer synchronizer;
public :
    // Constructor
    VisualAidingOpenni()
        :  nh("~")/*, it(nh)*/, synchronizer(1), ....
private:
void a function ()... {
        image_sub.subscribe(nh, topic_image, 1);
        pointcloud_sub.subscribe(nh, topic_pointcloud, 1);
        synchronizer.connectInput(image_sub, pointcloud_sub);
        synchronizer.registerCallback(boost::bind(&VisualAidingOpenni::subscriber_Callback,this , _1, _2));
void  subscriber_Callback(const sensor_msgs::ImageConstPtr& msg, const sensor_msgs::ImageConstPtr& pointcloud)
forget the word pointcloud, tried the depth image at last, so everything in sensor_msgs::image
this doesn't even compile
private:
    typedef sync_policies::ApproximateTime MySyncPolicy;
void function()
        image_sub = new message_filters::Subscriber(nh, topic_image, 1);
        pointcloud_sub = new message_filters::Subscriber(nh, topic_pointcloud, 1);
        synchronizer = new message_filters::TimeSynchronizer(MySyncPolicy(10), image_sub, pointcloud_sub);
i get this error
/opt/hector/students/friedrich/hector_visual_aiding/hector_visaid_monocular/src/visual_aiding_openni.cpp:-1: In Elementfunktion »void VisualAidingOpenni::CamInfo_Callback(const CameraInfoConstPtr&)«:
:-1: Fehler:[CMakeFiles/visual_aiding_openni.dir/src/visual_aiding_openni.o] Fehler 1
THX
Originally posted by Pitscho on ROS Answers with karma: 36 on 2012-08-24
Comment by jbohren on 2012-08-24:
Shouldn't "mysyncpolicy" be "MySyncPolicy"?
Comment by Pitscho on 2012-08-24:
i have no idea why it isn't upper case here, but it is in qtcreator
Also could you post the error in a codeblock, it's getting mangled.
Yeah, there's no information on the error there.
well, the error message just tells me in which function i have the error, nothing more-
i installed 11.10 these days after i had ubuntu 12.04. since then my debugger information isn't as accurate as before, i don't know why. i use qtcreator. build type is debug.
The build type wouldn't affect compiler errors.
Can you try building it on the command line?
You can set up a callback in ROS that synchronizes messages from multiple topics with a TimeSynchronizer: http://www.ros.org/wiki/message_filters#Time_Synchronizer
As Dan Lazewatsky says in the comments below, if the timestamps aren't identical, then you might be able to use an ApproximateTimePolicy with the TimeSynchronizer.
Originally posted by jbohren with karma: 5809 on 2012-08-24
hi, i did that, but .. the two topics i subscribe publish in different frequencies. i need the rgb and d information as synchron as possible.
/camera/rgb/image_color and /camera/depth_registered/image at the same time synchron would be perfect
Comment by Dan Lazewatsky on 2012-08-24:
Since the hardware doesn't synchronize the image acquisition, there is no way to get precisely synchronized images from a kinect. Using the ApproximateTime sync policy with a time synchronizer is probably your best option.
so the data in /camera/depth/pointcloud with xyzrgb information is also not really synchron for positon and color ?
