There seems to be consensus here that the BeagleBone Black has 1ms+ latency while toggling gpio pins due to the fact that gpio is handled outside of the cpu. Are the uart/i2c/spi lines equaly slow, or are they significantly faster?
I've seen references to people talking to the gpio more directly. Could this decrease uart/i2c/spi latencies as well?
  • $\begingroup$ What level of performance do you need? $\endgroup$
    – Ian
    Aug 5, 2014 at 1:49
  • $\begingroup$ 300 to 500μs would be ideal for my application. From what I can find the BBB supports up to 3mbaud uart, so an added 1ms can be a lot at those levels. However, I doubt it would be too noticeable in the i2c world... $\endgroup$
    – David
    Aug 5, 2014 at 5:56
