Curve
I am able to locate centroids of each blocks, but i am unable to join two blocks with a line segment by avoiding the obstacle as shown in the figure. Please need help how do i achieve this using matlab.
  • $\begingroup$ If you want programming help, you should include sample code (especially your world definition). Also, we are assuming that this is a robot navigation problem, but you should state this if it is the case--otherwise, there are very simple algorithms that can connect the centroids while avoiding the obstacle. $\endgroup$ – JSycamore Jul 6 '16 at 21:30
Sorry I do not know. But following course has your needed info
Some course can register while not running. Some need wait for run time.
Low-level motion (PID, point a to b) https://www.coursera.org/course/conrob.
High level path planning https://www.edx.org/course/tumx/tumx-autonavx-autonomous-navigation-1658
part 1 and of of this, https://courses.edx.org/courses/SNUx/SNU446.345.1x/1T2014/info
Fly https://www.edx.org/course/tumx/tumx-autonavx-autonomous-navigation-1658
  • $\begingroup$ okay so can you tell me, how to join two blocks with a line segment, ignoring the obstacle, i mean how can i draw a straight line between two blocks. $\endgroup$ – Naba Das Aug 3 '14 at 17:34
  • $\begingroup$ Block_1 x0,y0 Block_2_Robot x1,y1,speed,angle_of_movement (by robot sterling wheel as in 4 wheels car or differential drive for 2 wheel robot) $\endgroup$ – EEd Aug 3 '14 at 17:39
  • $\begingroup$ as this diagram, where robot is, where to go and what angle to go. intechopen.com/source/html/9117/media/image36.png $\endgroup$ – EEd Aug 3 '14 at 17:47
  • $\begingroup$ Am having difficulty with the coding part in matlab. I want to join the robot with the block by a line segment and then i want to move the robot by using the line segment as the reference point. $\endgroup$ – Naba Das Aug 3 '14 at 17:53
Have you tried the line() function, which plots a straight line on a figure?
You do something like
imshow(myImage);
hold on
line(X, Y);
Check help line for details.
  • $\begingroup$ ya i did, but actually i am unable to do so, can you please provide me a sample code. $\endgroup$ – Naba Das Aug 5 '14 at 16:22
