I think I might just be having a difficult time understanding how the coordinate frames relate to each other. I'm working on a visualization (very small subset of rviz) that is shown in a browser.
Basically I'm running SLAM and building a map. Using rosbridge I'm able to get the map and draw it. The base frame is /map and the associated OccupancyGrid has an origin which I translate and rotate by. This seems to work just fine.
Now I want to put an overlay of a robot footprint so you can see where it is, or it thinks it is in the map. Ideally I'd like to display a few topics under /move_base_node which have a base frame of /odom:
  • /move_base_node/local_costmap/robot_footprint
  • /move_base_node/local_costmap/obstacles
  • /move_base_node/local_costmap/inflated_obstacles
** In the end this is what worked for me **
As suggested I look up the transform between map and odom and then publish that on a new topic that I can subscribe to on the client end of rosbridge. Whenever I receive an update I use the transformation between map and odom on any topics with a base frame of odom to bring them into the map frame.
You can check the frames easily with: rostopic echo 'your_topic_name' | grep frame
int main(int argc, char** argv){
  ros::init(argc, argv, "my_tf_listener");
  ros::NodeHandle node;
  ros::Rate rate(1.0);
  tf::TransformListener listener;
  tf::StampedTransform tfTransform;
  tf::Vector3 origin;
  tf::Quaternion rotation;
  tf::Vector3 axis;
  static ros::Publisher publisher =
    node.advertise<geometry_msgs::TransformStamped>("/odom2map_transform",
                            10);
  geometry_msgs::TransformStamped geoTransform;
  int seq = 0;
  geoTransform.header.frame_id = "map";
  geoTransform.child_frame_id = "odom";
  while(node.ok()) {
    try {
      listener.lookupTransform(geoTransform.header.frame_id,
                   geoTransform.child_frame_id,
                   ros::Time(0),
                   tfTransform);
    catch(tf::TransformException &exception) {
      ROS_ERROR("%s", exception.what());
    origin = tfTransform.getOrigin();
    rotation = tfTransform.getRotation();
    axis = rotation.getAxis();
    geoTransform.header.seq = seq;
    geoTransform.header.stamp = tfTransform.stamp_;
    geoTransform.transform.translation.x = origin.x();
    geoTransform.transform.translation.y = origin.y();
    geoTransform.transform.translation.z = origin.z();
    geoTransform.transform.rotation.x = axis.x();
    geoTransform.transform.rotation.y = axis.y();
    geoTransform.transform.rotation.z = axis.z();
    geoTransform.transform.rotation.w = rotation.getW();
    seq++;
    publisher.publish(geoTransform);
    rate.sleep();
  return 0;
Originally posted by skiesel on ROS Answers with karma: 549 on 2012-08-17
Comment by skiesel on 2012-08-18:
I can't figure out where to respond to your comment? robot_footprint for example is in the /odom base frame. I want to figure out how to line up that coordinate frame with the /map frame. Basically I thought I was doing that above? The variables you reference are static, so they're only created once
Comment by Lorenz on 2012-08-19:
Right. Sorry. I missed that... Still I don't see what the sleep is for. I'll update my answer to be more specific.
If you just want to have the pose of the robot in map, all you need to do is look up the transform between /map and your base frame. There is no need to subscribe to the odom topic for that. The code for getting the pose of base_footprint in map would be:
tf::StampedTransform transform_in_map;
try {
  listener.lookupTransform("map", "base_footprint", ros::Time(0), transform_in_map);
} catch(tf::TransformException &exception) {
Most tools, e.g. rviz, are using this mechanism to calculate the robot pose with respect to map instead of directly subscribing to odom. I think the only node that really uses the odom topic on the pr2 is the move_base node because it needs the current velocity. Everything else uses tf.
Originally posted by Lorenz with karma: 22731 on 2012-08-18
Post score: 5
Comment by pgorczak on 2012-08-23:
The odom topic is also used by mapping and localization algorithms. What can be confusing is that there can be an odometry topic (nav_msgs/Odometry) without the transform being published to tf (for instance if you use robot_pose_ekf that provides the link between /odom and /base)
Comment by Lorenz on 2012-08-23:
According to the ros wiki, neither amcl nor gmapping or hector_mapping subscribe to the odom topic. I also checked the amcl source code, just in case the wiki is wrong. They all use tf, not the odom topic and that's why they work with robot_pose_ekf which publishes the odom->base_link transform.
Of course - my first sentence didn't make sense...
