Hi All,
Had anyone had any success creating a reasonable map in ROS with just sonar and odometry data?
If so I'd like to know what map type; setup etc you used.
Currently the map is a mess (An only home brew solution works just fine) so I'm sure it must be possible.
FYI the Sonar data is being published as both Range and laser_scan message types.
EDIT - Sonar Laser Code for benefit of others:
bool ToeminatorROSBridge::publishSonarAsLaserData(ros::Time time, RobotData* pRobotData)
tf::TransformBroadcaster laser_broadcaster;
ros::NodeHandle n;
// Laser/Sonar Range Test
bool publish_laser = true;
n.param("publish_laser", publish_laser, publish_laser);
ros::Publisher laser_pub;
if(publish_laser)
laser_pub = n.advertise<sensor_msgs::LaserScan>("sonar_laser_scan", 1000);
unsigned int num_readings = 7;
double laser_frequency = 2;
//populate the LaserScan message
sensor_msgs::LaserScan scan;
scan.header.stamp = time;
scan.header.frame_id = "base_laser";
scan.angle_min = -1.57;
scan.angle_max = 1.57;
scan.angle_increment = 3.14 / num_readings;
scan.time_increment = (1 / laser_frequency) / (num_readings);
scan.range_min = 0.0;
scan.range_max = 10.0;
scan.ranges.resize(num_readings+1);
scan.intensities.resize(num_readings+1);
for(int i=1; i<=7; i++)
scan.ranges[i] = pRobotData->SonarMeasurements[i-1]/100.0; // Convert to Meters
laser_pub.publish(scan);
laser_broadcaster.sendTransform(tf::StampedTransform(tf::Transform(tf::createQuaternionFromRPY(0, 0, degree_to_radian(ROS_FrontSonarAngle)),
tf::Vector3(0.0, 0.15, 0.0)),
scan.header.stamp,
"base_link",
"base_laser"));
return true;
Many Thanks
Mark
Originally posted by MarkyMark2012 on ROS Answers with karma: 1834 on 2012-08-15
Comment by Kristof on 2013-07-14:
Hi Mark, Did you make any progress on this? I am currently grappling with the exact same question. Thanks!
Comment by MarkyMark2012 on 2013-08-27:
Hi Kirstof - sorry for the late reply.
No not really - I upgraded to groovy and knackered my system & not really had time to sort it out. I was slightly perplexed why I couldn't get anything decent when my home brew app could do a reasonable job.
Comment by albert on 2016-05-25:
Hi Mark, I did the same thing with 13 sonar. But have problem to clear obstacles in map when the obstacle is not there anymore. Can you give me some advice?
Comment by MarkyMark2012 on 2016-05-31:
@albert What map(s) set up do you have?
Comment by albert on 2016-06-01:
I used the costmap_2d package in the navigation stack,
Comment by bill on 2017-01-12:
can you upload the code of costmap_2d ? i have the same problem
Comment by ahendrix on 2017-01-12:
costmap_2d is part of the navigation stack. Like most ROS packages, the link to the source code is on the costmap_2d wiki page, and that points to github: https://github.com/ros-planning/navigation
Comment by bill on 2017-01-13:
i mean ,how you connect the sonar data with the costmap_2d, sorry for the stupid question but i am new in ros
Comment by MarkyMark2012 on 2017-01-13:
@bil - Whilst I never did it - other suggest creating a course laserscan - the data of which is made up from the sonar results
Comment by ahendrix on 2017-01-13:
There's also now a costmap layer specifically for range (IR and ultrasonic) sensors: http://wiki.ros.org/range_sensor_layer . @bill if you have further specific questions it would be better to ask a new question.
