Hi all,
I successfully managed to get sound_play working on my machine.
I was just wondering if there is a way to use it through c/c++ code within my node.
I found something for python in http://www.pirobot.org/blog/0022/ but not for c/c++.
For the time being I used a system call within the code as follows: system("rosrun sound_play say.py "Hi There"");
A small barebone example code would be greatly appreciated.
Thanks in advance.
Originally posted by roboviz on ROS Answers with karma: 26 on 2012-08-14
sound_play exposes a C++ API that's documented here: http://docs.ros.org/latest-available/api/sound_play/html/index.html
There's a simple example here: http://docs.ros.org/latest-available/api/sound_play/html/test_8cpp_source.html
Originally posted by ahendrix with karma: 47576 on 2012-09-11
Comment by rodrigobdz on 2016-06-11:
The links are broken
The links are now found under the docs directory for each distribution
Comment by ahendrix on 2016-06-11:
Fixed the links. Thanks for catching that.
