I know there have been a few posts on SDF vs URDF for gazebo, but I'm still not sure I know which to use.
It particularly interests me when I see this in the terminal (running pr2_empty_world.launch ):
Warning [parser.cc:348] Gazebo SDF has no gazebo element
Warning [parser.cc:291] DEPRECATED GAZEBO MODEL FILE
On July 1st, 2012, this formate will no longer by supported
Convert your files using the gzsdf command line tool
You have been warned!
So, if I want to go to SDF, then I cannot run a robot controller, or at least cannot use robot_description param required to run a controller.
But if I stick with URDF, then it's deprecated? If I could input Collada files or SDF with the robot_description param, I think it would help.
I see the reference to a collada converter here but haven't seen anything on it since this ticket that's over a year old.
Has it been maintained?
Originally posted by phil0stine on ROS Answers with karma: 682 on 2012-08-13
Comment by cagatay on 2012-08-13:
Hello, I have a simmechnaics file( meshes are in stl format). I converted it to a urdf file then to a xacro file, I got the same warnings( gazebo_worlds/empty_world_paused). I am not whether these warnings affect my simulation in gazebo.
Comment by phil0stine on 2012-08-13:
Was the conversion straightforward? I know there are urdf->collada (or stl I assume) but didn't know of the reverse. Thanks
Comment by cagatay on 2012-08-14:
hello, yes the conversion was straightforward, I used simmechanics_to_urdf package but I got an tf exception error then I used another version of simmechanics_to_urdf package, no problem occured. But when i launch gazebo and my robot's urdf, I got error described by you, .dae is collada format i gue
Comment by ChengXiang on 2012-08-26:
Hi. i am a new user of gazebo with ROS and I get the similar warnings when i launched gazebo. May i know what should I do about the warnings? In addition, my gazebo often terminates unexpectedly, could these warnings be the reason for that?
Hi,
URDF will not be deprecated without a way to load it in gazebo, so no worries there. We've started the process of adding URDF parsing in gazebo, more details to come. At least for now (in Fuerte), there will not be any interrupted support for URDF spawning in gazebo.
Thanks, John
Originally posted by hsu with karma: 5780 on 2012-08-17
Comment by phil0stine on 2012-08-17:
Thanks. Might I ask if you know what ever happened with the ticket I referenced?
Comment by hsu on 2012-08-17:
hi, if the converter is broken, please file a new trac ticket against it? thanks,
Comment by 130s on 2012-12-29:
@hsu is there already update about URDF parsing?
Comment by arennuit on 2014-07-16:
I am new to ROS/gazebo and I thought that URDF was the historical format for ROS/gazebo and that gazebo had started to move away from URDF and to SDF. Am I wrong?
