Hello ROS community,
How to use rgbd-slam with two cameras? I have read http://www.ros.org/wiki/rgbdslam I run rgbd-slam from command line "roslaunch rgbdslam kinect+rgbdslam.launch" and it said: "cannot find kinect device". What should I put into command line in order to say rgbdslam reads frames(images) from two cameras, not from kinect device? Did anyone get success with it?
Also, I have tried to to use bagfiles instead of kinect device to get pre-saved frames(images), however did not get any success. Does anyone have example of using bagfiles?
My enviroment: Ubuntu 11.10 ROS electric 2 cameras
Thanks a lot, Alex
Originally posted by dalspenguin on ROS Answers with karma: 31 on 2012-08-13
You need to compute a pointcloud from your stereo vision data, then have rgbdslam listen to the 2d image and the cloud. Set the parameters "wide_topic" and "wide_cloud_topic" to listen to the topics where the respective data is published.
The cloud must be dense, i.e. stored in a 2D grid where each point corresponds to one pixel and vice versa.
Originally posted by Felix Endres with karma: 6468 on 2012-09-06
