Hi. I find kinect depth fomulas.
But, I'm wondering how to know relationship of depth value using OpenNi?
In libfreenect, this formulas
  1. float dist =100/(-0.0030711016*rawdisparity + 3.3309495161); //ros distance (cm)
  2. float dist2 = 12.36 * tanf(rawdisparity/ 2842.5 + 1.1863); //Stéphane Magnenat distance (cm)
Can I use the fomulas in OpenNi?
At (http://www.ros.org/wiki/kinect_calibration/technical)
There is the depth fomula
z = b*f / (1/8 * (doff - kd))
Is the same true for the OpenNi driver?
Can you talk to me how to get the depth relation?
I'm using ubuntu and OpenNi driver.
I saw the disparity has 11-bit value.
So disparity range is 0-2047.
If it is true, any disparity makes the formula's denominator zero(0).
Then, the formula is infinity.
How did this happen?
Disparity 11bit, is it right??
Originally posted by rosmaker on ROS Answers with karma: 51 on 2012-08-13
Hi,
If you are using OpenNI, then your Kinect should also be publishing on a topic called /camera/depth/image_raw. The images published on this topic are already calculated to real world depth with taking the Kinect as the origin. You shouldn't be needing a formula to calculate this on your own.
Hope this helps.
Originally posted by Hansg91 with karma: 1909 on 2012-08-20
The supported ROS depth image representations are described in REP-0118.
Originally posted by joq with karma: 25443 on 2012-08-16
