I am using ROS- electric. Now, I am able to built a octomap with the help of RGBDSLAM package. The map is in format '.bt'. Is there any packages available for doing localization and navigation in 3D using this octomap?
Note:localization should be done without using laser.
Originally posted by Sudhan on ROS Answers with karma: 171 on 2012-08-10
We have a 6D localization running in an OctoMap for our humanoid robots. You can find details in the publication "Humanoid Robot Localization in Complex Indoor Environments". It's runnning MCL (particle filtering) and uses ray casting for the sensor model.
The code is now published at http://ros.org/wiki/humanoid_localization
It's mostly designated for humanoid robots and still being polished right now, but I'm sure you can use much of the sensor model code as example.
If you want to implement your own localization, you can use the function castRay in OctoMap.
In terms of map building, planning, and collision checking in an OctoMap look at the 3d_navigation stack and the publication "Navigation in Three-Dimensional Cluttered Environments for Mobile Manipulation".
Originally posted by AHornung with karma: 5904 on 2012-08-10
Comment by Sudhan on 2012-08-10:
yes, I am interested and you can publish the codes. Is it possible to ray casting with kinect or LASER is necessary?
Comment by AHornung on 2012-08-10:
OctoMap doesn't care about your sensor. You can raycast with any distance sensor, all it needs is a direction and an origin. The sensor model may be a little harder to tweak though.
I have a kinect but it can't measure the objects lesser than 1.2m. Is there any solutions for that? Also, I saw one more package(3d_navigation) just now which is maintained by you. Both are same?
The minimum range should be around 0.7m, but that is the general problem with such a sensor. I added 3d_navigation to my answer, they serve different purposes. You will have to read the papers for the details.
Comment by AHornung on 2012-09-25:
The code is now public, I edited my answer. It's still being polished and finalized for point clouds, but it may give you some idea.
Comment by Sudhan on 2012-09-26:
Thank you very much
Comment by AHornung on 2012-09-28:
If your question is answered, please mark the answer as correct (checkmark).
Comment by Sudhan on 2012-10-10:
I marked this as a correct answer long back, but for some reasons the checkmark is not working in my browser properly.
