I use ubuntu 11.10 and fuerte.
When I rosmake my PCL project, it shows:
  sam@sam:~/code/ros/sam_pcl/wei_pcl_tutorial$ rosmake
  [ rosmake ] rosmake starting...
  [ rosmake ] No package specified.  Building ['wei_pcl_tutorial']
  [ rosmake ] Packages requested are: ['wei_pcl_tutorial']
  [ rosmake ] Logging to directory /home/sam/.ros/rosmake/rosmake_output-20120810-175832
  [ rosmake ] Expanded args ['wei_pcl_tutorial'] to:
  [rosmake-0] Starting >>> std_msgs [ make ]
  [rosmake-0] Finished <<< std_msgs  No Makefile in package std_msgs
  [rosmake-0] Starting >>> geometry_msgs [ make ]
  [rosmake-0] Finished <<< geometry_msgs  No Makefile in package geometry_msgs
  [rosmake-0] Starting >>> sensor_msgs [ make ]
  [rosmake-0] Finished <<< sensor_msgs  No Makefile in package sensor_msgs
  [rosmake-0] Starting >>> pcl [ make ]
  [rosmake-0] Finished <<< pcl  No Makefile in package pcl
  [rosmake-0] Starting >>> roslang [ make ]
  [rosmake-0] Finished <<< roslang  No Makefile in package roslang
  [rosmake-0] Starting >>> roscpp [ make ]
  [rosmake-0] Finished <<< roscpp  No Makefile in package roscpp
  [rosmake-0] Starting >>> rosbag [ make ]
  [rosmake-0] Finished <<< rosbag  No Makefile in package rosbag
  [rosmake-0] Starting >>> rosbuild [ make ]
  [rosmake-0] Finished <<< rosbuild  No Makefile in package rosbuild
  [rosmake-0] Starting >>> roslib [ make ]
  [rosmake-0] Finished <<< roslib  No Makefile in package roslib
  [rosmake-0] Starting >>> rosconsole [ make ]
  [rosmake-0] Finished <<< rosconsole  No Makefile in package rosconsole
  [rosmake-0] Starting >>> pluginlib [ make ]
  [rosmake-0] Finished <<< pluginlib ROS_NOBUILD in package pluginlib
  [rosmake-0] Starting >>> rospy [ make ]
  [rosmake-0] Finished <<< rospy  No Makefile in package rospy
  [rosmake-0] Starting >>> bond [ make ]
  [rosmake-0] Finished <<< bond ROS_NOBUILD in package bond
  [rosmake-0] Starting >>> smclib [ make ]
  [rosmake-0] Finished <<< smclib ROS_NOBUILD in package smclib
  [rosmake-0] Starting >>> bondcpp [ make ]
  [rosmake-0] Finished <<< bondcpp ROS_NOBUILD in package bondcpp
  [rosmake-0] Starting >>> nodelet [ make ]
  [rosmake-0] Finished <<< nodelet ROS_NOBUILD in package nodelet
  [rosmake-0] Starting >>> message_filters [ make ]
  [rosmake-0] Finished <<< message_filters  No Makefile in package message_filters
  [rosmake-0] Starting >>> rosservice [ make ]
  [rosmake-0] Finished <<< rosservice  No Makefile in package rosservice
  [rosmake-0] Starting >>> dynamic_reconfigure [ make ]
  [rosmake-0] Finished <<< dynamic_reconfigure ROS_NOBUILD in package dynamic_reconfigure
  [rosmake-0] Starting >>> nodelet_topic_tools [ make ]
  [rosmake-0] Finished <<< nodelet_topic_tools ROS_NOBUILD in package nodelet_topic_tools
  [rosmake-0] Starting >>> rostest [ make ]
  [rosmake-0] Finished <<< rostest  No Makefile in package rostest
  [rosmake-0] Starting >>> bullet [ make ]
  [ rosmake ] Last 40 linesllet: 3.3 sec ]        [ 1 Active 21/28 Complete ]
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h: In function 「void ZeroInitialize(T&) [with T = btSoftBody::Node]」:
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.cpp:80:19:   instantiated from here
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h:175:17: 錯誤: 未初始化的常數 「zerodummy」 [-fpermissive]
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.h:193:9: 附註: 「const struct btSoftBody::Node」 has no user-provided default constructor
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h: In function 「void ZeroInitialize(T&) [with T = btSoftBody::Material]」:
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.cpp:157:21:   instantiated from here
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.h:179:9: 附註: 「const struct btSoftBody::Material」 has no user-provided default constructor
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h: In function 「void ZeroInitialize(T&) [with T = btSoftBody::Note]」:
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.cpp:172:18:   instantiated from here
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.h:267:9: 附註: 「const struct btSoftBody::Note」 has no user-provided default constructor
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h: In function 「void ZeroInitialize(T&) [with T = btSoftBody::Link]」:
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.cpp:243:20:   instantiated from here
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.h:206:9: 附註: 「const struct btSoftBody::Link」 has no user-provided default constructor
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h: In function 「void ZeroInitialize(T&) [with T = btSoftBody::Face]」:
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.cpp:280:20:   instantiated from here
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.h:217:9: 附註: 「const struct btSoftBody::Face」 has no user-provided default constructor
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBodyInternals.h: In function 「void ZeroInitialize(T&) [with T = btSoftBody::Tetra]」:
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.cpp:315:20:   instantiated from here
    /home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn/src/BulletSoftBody/btSoftBody.h:225:9: 附註: 「const struct btSoftBody::Tetra」 has no user-provided default constructor
    make[5]: Leaving directory `/home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn'
    make[5]: *** [src/BulletSoftBody/CMakeFiles/BulletSoftBody.dir/btSoftBody.o] Error 1
    make[4]: Leaving directory `/home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn'
    make[3]: Leaving directory `/home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn'
    make[2]: Leaving directory `/home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet/build/bullet_svn'
    make[1]: Leaving directory `/home/sam/code/ros/sam_perception/sam_recognition/eigen/bullet'
    make[4]: *** [src/BulletSoftBody/CMakeFiles/BulletSoftBody.dir/all] Error 2
    make[3]: *** [src/BulletSoftBody/CMakeFiles/BulletSoftBody.dir/rule] Error 2
    make[2]: *** [BulletSoftBody] Error 2
    make[1]: *** [installed] Error 2
    CMake Error at CMakeLists.txt:14 (message):
      Build of Bullet failed
  [ rosmake ] Output from build of package bullet written to:
  [ rosmake ]    /home/sam/.ros/rosmake/rosmake_output-20120810-175832/bullet/build_output.log
  [rosmake-0] Finished <<< bullet [FAIL] [ 3.40 seconds ]
  [ rosmake ] Halting due to failure in package bullet.
  [ rosmake ] Waiting for other threads to complete.
  [ rosmake ] Results:
  [ rosmake ] Built 22 packages with 1 failures.
  [ rosmake ] Summary output to directory
How to solve it?
Thank you~
Originally posted by sam on ROS Answers with karma: 2570 on 2012-08-10
Something seems to be messed up with your ros workspace. Why does it try to compile bullet at all? It should be installed by the debian package ros-fuerte-bullet. Try cleaning up your ros workspace and get rid of the directory bullet and its parent eigen.
Originally posted by Lorenz with karma: 22731 on 2012-08-10
Comment by sam on 2012-08-10:
What is clean up,get rid of bullet and eigen means? What should I do? Thank you~
Comment by Lorenz on 2012-08-10:
You have a directory eigen in /home/sam/code/ros/sam_perception/sam_recognition/. I believe it should not be there. In fuerte there is no package eigen anymore. Also, there is a subdirectory bullet in eigen that should definitely not be there.
