Hey,
OS: Fedora 14 ROS: Fuerte
Error, while initializing roscore:
Unable to contact my own server at [http://scitos:50689/]. This usually means that the network is not configured properly.
A common cause is that the machine cannot ping itself. Please check for errors by running:
ping scitos
For more tips, please see
http://www.ros.org/wiki/ROS/NetworkSetup
ping scitos delivers
unkown host scitos
ping localhost works fine, ping 127.0.0.1 likewise
Solutions according to ros-wiki is to set
ROS_HOSTNAME=localhost ROS_MASTER_URI=http://localhost:11311
this has not worked ping $ROS_HOSTNAME does fine, while ping $ROS_MASTER_URI returns
unknown host http://localhost:11311
Any ideas why this does not work? Maybe some issue concerning my network connection(using wireless for internet, still there are two ethernet accesses, which are currently not used)?
thx :-)
Originally posted by Flowers on ROS Answers with karma: 342 on 2012-07-30
It's clear that you can't ping the ROS_MASTER_URI. Pinging the host in the ROS_MASTER_URI is the correct way.
Could you run a roscore after setting ROS_HOSTNAME?
The other way is checking your /etc/hosts. There should probably be a line like:
127.0.0.1   localhost
If you add
127.0.0.1   scitos
after that, you should be able to do ping scitos.
Originally posted by dornhege with karma: 31395 on 2012-07-30
