Hello, trying to install stage on a working ROS (fuerte) install (verified through all tutorials), but at some point when I try to rosmake:
/usr/bin/ld: CMakeFiles/bin/stageros.dir/src/stageros.o: undefined reference to symbol '_ZN2Fl4waitEd' /usr/bin/ld: note: '_ZN2Fl4waitEd' is defined in DSO /lib/libfltk.so.1.3 so try adding it to the linker command line
/lib/libfltk.so.1.3: could not read symbols: Invalid operation collect2: error: ld returned 1 exit status
make[4]: *** [../bin/stageros] Error 1
No problems with rosdep either.
I thought this was related to this ticket, but shouldn't this be fixed? https://code.ros.org/trac/ros-pkg/ticket/4441
Thanks so much for any help!
Originally posted by user12821821 on ROS Answers with karma: 45 on 2012-07-27
Comment by Asomerville on 2012-07-27:
I don't know the answer, but what version of ROS you're working with will be important to answering the question.
On Fedora, that reference is supposed to be satisfied by installing fltk-devel.
What does this do?
$ rosdep install stage
UPDATE: try this, then check to see if the fltk package named is actually installed:
$ rosdep resolve fltk
UPDATE2: that #4441 fix was to an older version of stage (3.2.2). Fuerte has stage 4.1.1.
I can't tell whether or not that fix was ever applied upstream. It may have gotten lost in the version upgrade.
I recommend opening a new ticket for Fuerte, referring back to #4441 and to this question.
Originally posted by joq with karma: 25443 on 2012-07-27
Comment by user12821821 on 2012-07-27:
When I do "rosdep install stage" I get the message: "#All required rosdeps installed successfully" then when I retry rosmake I get the exact same error.
When I do "rosdep resolve fltk" I get the message: "#yum" followed by the message "fltk-devel" , when I retry rosmake I get the exact same error.
Comment by joq on 2012-07-28:
Does yum say fltk-devel is actually installed?
Comment by user12821821 on 2012-07-29:
When I do yum list installed I have entries for : "fltk.i686", "fltk-devel.i686", "fltk-fluid.i686" and all of these three have a version of 1.3.0-4.fc17 thanks so much for your help btw it is greatly appreciated.
Comment by user12821821 on 2012-07-30:
Okay thanks so much for your help, submitted a ticket #5507
For anyone still having issues, this patch fixes things for fedora: https://code.ros.org/trac/ros-pkg/attachment/ticket/5507/fltk-find-package.patch
Originally posted by cottsay with karma: 311 on 2013-01-28
Comment by user12821821 on 2013-03-07:
Thanks for the update!
