Hi I am using ubuntu 11.10 with ROS electric and Kinect.
when i run the application, it works fine in pause state. Upon processing, it results in exit with following message.
bool g2o::HyperGraphActionLibrary::registerAction(g2o::HyperGraphElementAction*): creating collection for "writeGnuplot" bool g2o::HyperGraphActionLibrary::registerAction(g2o::HyperGraphElementAction*): creating collection for "draw"
(rgbdslam:2800): Gtk-WARNING **: Unable to locate theme engine in module_path: "pixmap",
(rgbdslam:2800): Gtk-WARNING *: Unable to locate theme engine in module_path: "pixmap", [rgbdslam-1] process has died [pid 2800, exit code -11]. log files: /home/vision-lab/.ros/log/fb3c4690-d763-11e1-aad7-f80f4113f0b0/rgbdslam-1.log all processes on machine have died, roslaunch will exit shutting down processing monitor... ... shutting down processing monitor complete done
Please tell what is missing and why I am getting this reply.
Originally posted by Tahir on ROS Answers with karma: 1 on 2012-07-26
Comment by Tahir on 2012-07-26:
It works good with roslaunch rgbdslam kinect+rgbdslam.launch
The only relevant information is this:
Signal 11 roughly means that a memory segment is accessed that doesn't belong to the process. You probably need to run it in a debugger to get to the source of this error.
How do you start it? A standard launch file? A custom one?
Originally posted by Felix Endres with karma: 6468 on 2012-07-30
sudo apt-get install gtk2-engines-pixbuf
hope this helps...:)
Originally posted by Yum.my with karma: 11 on 2012-07-28
