follow:pluginlib
I see all of the documentation in pluginlib.
I think to use of time in pluginlib.
Thank you.
Originally posted by li-an on ROS Answers with karma: 67 on 2012-07-23
What exactly do you want to know?
If you refer to "what is the purpose of pluginlib": The pluginlib package provides tools for writing and dynamically loading plugins using the ROS build infrastructure.
Originally posted by dornhege with karma: 31395 on 2012-07-24
Comment by li-an on 2012-07-24:
In tutorials here is only one package with two algorithms,how is show dynamically loading plugins ?
Comment by dornhege on 2012-07-24:
You mean the Square/Triangle example? They are loaded dynamically in 1.7.
I do not want to be rude. Are you asking when pluginlib architecture is used? If yes, then you can have look at navigation stack setup, specifically move_base. Which global planner to use, can be configured in launch files and corresponding library will get loaded. Pluginlib allow to do that.
Originally posted by prince with karma: 660 on 2012-07-24
Comment by prince on 2012-07-24:
dornhege gave more appropriate answer :)
