Hi!
I'm working with Ubuntu 10.04 and ROS Electric to deal with the Robotnik Summit robot. When installing the navigation_experimental stack (https://kforge.ros.org/navigation/experimental), I have some problems when building these two packages:
sbpl_lattice_planner sbpl_recovery
When doing the "rosmake" for those two packages, I get the same error, this one:
CMake Error at /usr/share/cmake-2.8/Modules/FindPkgConfig.cmake:266 (message): A required package was not found Call Stack (most recent call first): /usr/share/cmake-2.8/Modules/FindPkgConfig.cmake:320 (_pkg_check_modules_internal) CMakeLists.txt:15 (pkg_check_modules)
When doing the "rosdep install", it says that the package "sbpl" cannot be found. But the strange thing is that I have that package installed. In fact, if I do:
rospack find sbpl
It finds the package, with this path:
/opt/ros/electric/stacks/sbpl
The path of navigation_experimental is:
/opt/ros/electric/stacks/navigation_experimental
The "rospack find" finds the sbpl package, but when installing other packages it can't find it.
Any ideas?
Thank you very much!
Originally posted by egoitzas on ROS Answers with karma: 46 on 2012-07-23
I'm willing to bet you're using the fuerte version of navigation_experimental with the electric version of SBPL. The fuerte version uses the new build system which treats SBPL as a system dependency instead of a ROS package. Assuming you checked navigation_experimental out from source control, you should be able to checkout the tagged 'electric' version which looks for the 'ROS package' version of SBPL.
Originally posted by adornbush with karma: 91 on 2012-07-25
