Hey there,
i've a problem using the getPath() function from roslib package. I need the package path to read out some images for a gui. In ROS Electric the code snippet below works, but since the import to ROS Fuerte I get following error while linking the package:
...RoombaDashboard.cpp:43: undefined reference to `ros::package::getPath(std::basic_string<char, std::char_traits, std::allocator > const&)'
#include <ros/package.h>
/* Load PNGs */
wxString imgPath = wxString::FromAscii((
    ros::package::getPath("roomba_dashboard") + "/gui/").c_str());
Does anyone have an idea why this error occurs!? The source code seems to be right...
Thank you und best regards Stefan
Originally posted by Dark-Valentine on ROS Answers with karma: 146 on 2012-07-23
The problem is solved...
It seems that the roslib package isn't a dependency of roscpp anymore. Adding the roslib package as dependency to my package makes it linkable.
roscpp manifest.xml in electric
<depend package="roslib"/>
roscpp manifest.xml in fuerte
<package>
  <description brief="ROS C++ client library">
  </description>
  <author>Morgan Quigley [email protected], Josh Faust [email protected], Brian Gerkey [email protected], Troy Straszheim straszheim@will$
  <license>BSD</license>
  <review status="Doc reviewed"/>
  <url>http://ros.org/wiki/roscpp</url>
  <depend package="roslang"/>
  <export>
    <cpp cflags="`PKG_CONFIG_PATH=${prefix}/../../lib/pkgconfig pkg-config --cflags roscpp`"
         lflags="`PKG_CONFIG_PATH=${prefix}/../../lib/pkgconfig pkg-config --libs roscpp`"/>
    <roslang cmake="${prefix}/rosbuild/roscpp.cmake"/>
  </export>
  <rosdep name="pkg-config"/>
</package>
Thanks anyway!
Originally posted by Dark-Valentine with karma: 146 on 2012-07-23
Post score: 10
