Hello
I tried to launch the laser_scan_matcher package node. This is my launch file, but I can not see nothing on my rviz tool. Is something wrong with my launch file or just a rviz configuration? The launch file is like this
<node name="rosplay" pkg="rosbag" type="play" args="/home/Daniel/Desktop/Data/test-41.bag           --clock"/>
<node pkg="tf" type="static_transform_publisher" name="baselink_laser" args="0 0 0 0 0 0 /base_link /laser 10"/>
<node pkg="tf" type="static_transform_publisher" name="laser_imu" args="0 0 0 0 0 0 /laser /base_imu 10"/>
<node pkg="tf" type="static_transform_publisher" name="baselink_camera" args="0 0 0 0 0 0 /base_link /camera 10"/>
<node pkg="laser_scan_matcher" type="laser_scan_matcher_node"
    name="laser_scan_matcher_node" output="screen">
    <param name="use_alpha_beta" value="true"/>
    <param name="max_iterations" value="10"/>
</node>
<!-- Start an rviz node with a custom configuration for the viewpoint, map_server, trajectory, laser scans, etc -->
<node pkg="rviz" type="rviz" output="screen" name="rviz" args="-d $(find pow_analyzer)/launch/pow_rviz.vcg"/>
Originally posted by Astronaut on ROS Answers with karma: 330 on 2012-07-21
Comment by Astronaut on 2012-07-22:
The bag file is 150 sec long. So have to add this loop . Wright? And the Rviz settings?I mean the target and fixed frame?
Comment by Astronaut on 2012-07-23:
Any help on this?
rosbag is only going to play the data once. How long is that file?
If you want to play back the file repeatedly, add --loop to the rosbag arguments.
Originally posted by joq with karma: 25443 on 2012-07-21
