Hi,i am trying to install the turtle_teleop. I tried running the command "rosdep install turtle_teleop" and got the following error.what should I do?
ERROR: Rosdep cannot find all required resources to answer your query Missing resource turtle_teleop ROS path [0]=/opt/ros/fuerte/share/ros ROS path [1]=/opt/ros/fuerte/share ROS path [2]=/opt/ros/fuerte/stacks
Originally posted by hcx31 on ROS Answers with karma: 1 on 2012-07-20
I think I have found the problem. The package is named "turtlebot_teleop", not "turtle_teleop".
allenh1@muri-pc7:~$ rospack find turtle_teleop
[rospack] Error: stack/package turtle_teleop not found
allenh1@muri-pc7:~$ rospack find turtlebot_teleop
/opt/ros/fuerte/stacks/turtlebot_apps/turtlebot_teleop
I am running Ubuntu 12.04. I installed ROS with the package manager. If you did otherwise, then this answer may not be correct; however, I imagine the package names are static on most platforms. Let me know if this doesn't work!
Originally posted by allenh1 with karma: 3055 on 2012-07-23
