Hi all,
Not sure what's the matter here. If I use rostopic list, when my publisher has advertises Sonar messages I see /Sonar in the list. However if I try just the IR data it sometimes works most of the time not. The ad code is simply:
    // Sonar Range Test
    /*  bool publish_sonar = true;
n.param("publish_sonar", publish_sonar, publish_sonar);
ros::Publisher sonar_pub;
if(publish_sonar)
    sonar_pub = n.advertise<sensor_msgs::Range>("Sonar", 1000);
    */  // IR Range Test
bool publish_ir = true;
n.param("publish_ir", publish_ir, publish_ir);
ros::Publisher ir_pub;
if(ir_pub)
    ir_pub = n.advertise<sensor_msgs::Range>("InfraRed", 1000);
Any suggestions would me v welcome - I want my node to publish both at the end of the day. The TF for both works fine.
Many Thanks
Mark
Originally posted by MarkyMark2012 on ROS Answers with karma: 1834 on 2012-07-20
You probably want your IR if statement to be:
if(publish_ir)
not
if(ir_pub)
I would expect doing if(ros::Publisher) before it has been created using e.g. n.advertise to return false.
Originally posted by Eric Perko with karma: 8406 on 2012-07-20
Comment by MarkyMark2012 on 2012-07-22:
yes that was it. Thanks Eric
