i have created a robot model for rviz in urdf format.....how can i use this model on gazebo...i mean what changes do i have to make???
Originally posted by Sanket_Kumar on ROS Answers with karma: 234 on 2012-07-17
Comment by Sanket_Kumar on 2012-07-17:
thnks @erwan r. it worked :-)
but there is only one problem whenever i set static="false" my object runs into a corner of my world
Comment by Erwan R. on 2012-07-17:
Not sure about it but static prevents objects to move (another point of view required). If set to false and your object is colliding another one, force effects will throw your object away.
URDF models can be spawned in Gazebo according this tutorial.
You have to ensure that all required fields in urdf are present (visual but also collision, inertia ...) to be sure that you model will be displayed.
Originally posted by Erwan R. with karma: 697 on 2012-07-17
hey i found a command that can convert .urdf files to .model files for gazebo
rosrun gazebo urdf2model -f basic.urdf -o basic.model
Originally posted by Sanket_Kumar with karma: 234 on 2012-07-18
Comment by Erwan R. on 2012-07-18:
??? Gazebo provides several tools that you can check there. I don't know what your application is, but you can use both urdf and models. I don't know if there're equivalent.
Comment by Sanket_Kumar on 2012-07-18:
but in my gazebo i m not able to spawn urdf files my gazebo always crashes
so this is better option
The final solution is your choice, but maybe you could describe more the problem to understand why spawning urdf files make gazebo crash. Urdf files should spawn as well as models, so maybe there is a bug to be reported or a wrong practice to correct. But that's your choice.
Comment by gpsinghsandhu on 2012-08-10:
thnk u this troubled one of my collegues for days
