Hello guys,
i have a problem to run the pubsub tutorial project in rosjava. I build rosjava_core successfully and followed this tutorial http://docs.rosjava.googlecode.com/hg/rosjava_core/html/getting_started.html but the step "Executing nodes" doesn't work for me unfortunatelly. The build process (../gradlew installApp) runs without any errors (only a warning "bootstrap class path not set in conjunction with -source 1.6") but there is no path "/rosjava_tutorial_pubsub/bin/rosjava_tutorial_pubsub" in directory build. Even the executable nodes (Talker and Listener) cannot be found anywhere in the project. Maybe the tutorial isn't up to date here?
thanks
Originally posted by ChrisEule on ROS Answers with karma: 26 on 2012-07-13
I also ran into the same problem and think there is an error in the tutorial. To execute the example, I had to change:
./build/rosjava_tutorial_pubsub/bin/rosjava_tutorial_pubsub org.ros.rosjava_tutorial_pubsub.Talker & ./build/rosjava_tutorial_pubsub/bin/rosjava_tutorial_pubsub org.ros.rosjava_tutorial_pubsub.Listener
to:
./build/install/rosjava_tutorial_pubsub/bin/rosjava_tutorial_pubsub org.ros.sjava_tutorial_pubsub.Talker & ./build/install/rosjava_tutorial_pubsub/bin/rosjava_tutorial_pubsub org.ros.sjava_tutorial_pubsub.Listener
Originally posted by liangfok with karma: 328 on 2012-07-21
Comment by uzair on 2013-11-23:
What ROS version is used for this tutorial?
I just ran the tutorials, and they worked fine for me. I summarized what I found on a tutorial wiki page. http://ros.org/wiki/rosjava_core/Tutorials
For me the executable is located in build/install.
Maybe you can paste the contents of your build.gradle as well as the results of
$ find src
$ find build
here so that it is easier to understand what happened. For now I would suspect that you did not create the folder structure src/main/java as required by gradle.
Originally posted by KruseT with karma: 7848 on 2012-07-13
