Hi,
I am using RGBDSLAM on Ubuntu 11.10, on ROS Electric, and a Kinect camera. My goal is to basically move around my room with the camera and create a 3-D map of my room. I guess that just means turning up the RGBDSLAM GUI on the terminal, and then hitting space to record data from the video stream generated. I am wondering, after this, I can simply save these data, but do I have to do anything further? Say, for instance, write some code to further process this data? Or that is enough for the sole purpose I am trying to achieve?
Thanks.
Originally posted by periphery on ROS Answers with karma: 21 on 2012-07-03
Comment by sai on 2012-11-20:
Hi periphery, Were you able to get rgbdslam running on ur system using kinect?
Depends on what you want your map to be, but in principle yes. If it should just be a big point cloud, saving is all you need. Maybe trigger optimization (Key "o") before you do so. If you want a volumetric map, use the octomap_server and use "send whole model" (and trigger the octomap_saver later).
Originally posted by Felix Endres with karma: 6468 on 2012-07-09
