I've been trying to get ROS and Care-O-Bot installed and running for some time now. I can never get Gazebo to initialize properly. I'm using Ubuntu 10.04, and Fuerte
I start with the instructions here:
http://www.ros.org/wiki/fuerte/Installation/Ubuntu
http://www.ros.org/wiki/Robots/Care-O-bot/fuerte
Then these:
http://www.ros.org/wiki/cob_bringup_sim
I can get through all of the ROS tutorials, so I believe that everything has been done correctly with respect to ROS, but when I run cob_bringup_sim Gazebo fails with the following error:
Error [Plugin.hh:100] Failed to load plugin -1: -1: cannot open shared object file: No such file or directory
Warning [parser.cc:332] Gazebo SDF has no gazebo element
Warning [parser.cc:243] parser for sdf version 1.0 failed, trying to parse as old deprecated format
Segmentation fault
For reference, here is the Gazebo cmd that cob_bringup_sim generates, running this line solo creates the same error:
/opt/ros/fuerte/stacks/simulator_gazebo/gazebo/scripts/gazebo -s -1 /opt/ros/fuerte/stacks/cob_environments/cob_gazebo_worlds/common/worlds/empty.world __name:=gazebo __log:=/home/nathan/.ros/log/58188a6e-bee5-11e1-bd07-f46d0412dc71/gazebo-2.log
No log file is generated, and I can only assume that Gazebo never even attempts to load.
Originally posted by natbur on ROS Answers with karma: 26 on 2012-06-25
Comment by pkohout on 2012-07-10:
what file is missing ?? i think there should be any .so file or so by: Error [Plugin.hh:100] Failed to load plugin -1: -1: cannot open shared object file: No such file or directory
It seems to stem from the combination of Fuerte and COB. As soon as I rolled back to Electric, everything started working. Not sure if something has changed in the format of the simulation files for Fuerte that makes the current COB code not work, but for now I'm just sticking to Electric.
Originally posted by natbur with karma: 26 on 2012-08-08
