I'd like to ask that
  1. how to use pointcloud_to_laserscan
  2. Can rgbdslam package be used for creating a map for navigation stack?
I'd like to create a map data with kinect sensor for navigation. I've already read some tutorials and found that I have to use not cloud data but laser scan data.
pointcloud_to_laserscan can convert data, but the usage is not described in the wiki. Could you teach me how to use it?
And I found that rgbdslam can create a map using kinect. Is this package able to generate a map for navigation stack?
Originally posted by moyashi on ROS Answers with karma: 721 on 2012-06-24
Comment by prince on 2012-06-25:
Had looked at this similar question http://answers.ros.org/question/9450/how-to-setup-pointcloud_to_laserscan/
Comment by Felix Endres on 2012-06-26:
Also see this: http://answers.ros.org/question/12995/2d-map-from-octomap/
RGBDSlam is the best choice if you have both the rgb and depth stream, but Depthimage_to_laserscan is better if you only have the depth data (my project is like this). Depthimage_to_laserscan requires two things, the depth image topic and the camera_info topic (see monocular camera calibration tutorials). You'll also need to set up a coordinate frame to reference the kinect to. For example, with my stationary kinect 360, I use these:
rosrun tf static_transform_publisher 0 0 0 0 0 0 map camera_depth_frame 20
rosrun depthimage_to_laserscan depthimage_to_laserscan image:=/kinect/mono16/image_raw camera_info:=/kinect/mono16/camera_info _scan_height:=20 _scan_time:=0.167 _range_min:=0.75 _range_max:=2.5
You'd probably want to use a larger scan height if possible, but my slow little raspberry pi cannot handle much more than 640x40 at 6fps, so im limited in height.
After that, you'll see a new /scan topic. Use that in place of a laser scanner as described in the navigation stack tutorials: http://wiki.ros.org/navigation/Tutorials/RobotSetup
Originally posted by TimboInSpace with karma: 141 on 2015-03-23
