Hi, (ROS - Electric; Ubuntu 11.04) This is in continuation to the question. I am trying to build a 3D occupancy map using the octomap_server with kinect sensor on top of the turtlebot. Following are the launch files i ran
roslaunch turtlebot_bringup minimal.launch
roslaunch turtlebot_navigation gmapping_demo.launch
Turtlebot navigation package launches the /turtlebot_bringup/kinect.launch which has the throttling and fake laser for 2D mapping and localization purposes.
Now i try to run the
roslaunch octomap_server octomap_mapping.launch
I have modified the cloud_in and frame_id as given below
<launch>
    <node pkg="octomap_server" type="octomap_server_node" name="octomap_server">
        <param name="resolution" value="0.05" />
        <!-- fixed map frame (set to 'map' if SLAM or localization running!) -->
        <param name="frame_id" type="string" value="/map" />
        <!-- maximum range to integrate (speedup!) -->
        <param name="max_sensor_range" value="3.0" />
        <!-- data source to integrate (PointCloud2) -->
        <remap from="cloud_in" to="/camera/depth/points" />
    </node>
</launch>
But the occupied_cells_vis_array topic gets the marker_array in the camera_depth_frame which is orthogonal to the actual kinect frame where the fake laser is being published. Hence i changed the frame using
<param name="frame_id" type="string" value="/camera_depth_optical_frame" />
to get it to the frame of actual kinect. But this leads to the Map being build to be orthogonal to the kinect frame. The resulting image is attached here.
I am sure that the gmapping is able to convert the camera_depth_optical_frame of the kinect to camera_depth_frame internally and creates the Map correctly. But when octomap_server is run this Map is again reframed. Please help me to resolve this issue.
Originally posted by karthik on ROS Answers with karma: 2831 on 2012-06-20
Hi, My colleagues were successful in finding the solution.
Fixed frame in rviz as: /odom
Target frame as: /camera_depth_frame
In the octomap_server/octomap_mapping.launch file with frame_id as /odom. We are able to get the 3D mapping done.
Originally posted by karthik with karma: 2831 on 2012-06-20
Comment by Fabian Saccilotto on 2013-01-17:
I am trying the same. But actually I can produce a quite good map with gmapping but when I connect the pointcloud to octomap as you do it, the octomap has a lot of artefacts from the situations were the robot's position inside the map is not correct. Did you have this problem too?
Comment by karthik on 2013-01-19:
Yes, i mean the fusing of the maps are not so great as the 3D occupancy grids are not getting updated with respect to their probabilities I guess. It took a lot of effort to get a good map with Kinect sensor. I think either you need a good odometry or a good sensor to get a good map at the least.
Comment by AHornung on 2013-01-20:
Try adding a Hokuyo laser to your robot for 2D. It will give you much better pose estimates in amcl or gmapping.
Comment by Gazer on 2013-07-10:
hi, guys I also get octomap working. As pointed out by above, the 3D map is not updated; the image (with wrong location) stays in the map and will never be erased. I am wondering how do you guys solve such problems?
Comment by emteasee on 2013-07-16:
Hi I cannot get the octomap working using the proposed solution above. There are no issues with Kinect connectivity. The camera is working as required, I just cannot see the visualisation of the pointcloud as shown in the example above? Could anyone help
Comment by Vegeta on 2014-02-04:
I was able to produce the 3d map, but the density of point cloud is very small. The points are very widely spaced. What might be the reason. How do I change this parameter?? Can you help?
