Do you have any idea ** to correct the following warning setting?
[WARN] [1340092854.777455509]: Message from [/hokuyo] has a non-fully-qualified
frame_id [laser]. Resolved locally to [/laser]. This is will likely not work in multi-robot systems. This message will only print once. [WARN] [1340092854.968655384]: Message from [/hector_mapping] has a non-fully-qualified frame_id [laser]. Resolved locally to [/laser]. This is will likely not work in multi-robot systems. This message will only print once. [ERROR][1340123076.274228430]: Trajectory Server: Transform from /map to /base_link failed: Unable to lookup transform, cache is empty, when looking up transform from frame [/base_link] to frame [/map] [ERROR] [1340123076.523439543]: Trajectory Server: Transform from /map to /base_link failed: Unable to lookup transform, cache is empty, when looking up transform from frame [/base_link] to frame [/map]
Originally posted by jas on ROS Answers with karma: 33 on 2012-06-19
Set the frame_id to /laser and the warnings will go away.
Originally posted by tfoote with karma: 58457 on 2012-07-23
Comment by kedarm on 2013-10-03:
Although I agree that this solution will work for single robot settings, I think a better and more robust solution is given here: https://code.ros.org/trac/ros-pkg/ticket/5511
Frames gets defined in a hierarchy like parent_frame/child_frame. If a frame do not have any parent, it is defined as /frame. First warning is :
 Message from [/hokuyo] has a non-fully-qualified  frame_id [laser]. Resolved locally to [/laser].
It is advisable to fully specify the hierarchy when using frames as using just name could lead to ambiguity in choosing the correct frame. This will definitely cause problem in multi-robot scenario. About following errors:
You are not publishing tf for: map --> base_link
Point no. 17 at link http://www.ros.org/wiki/tf/FAQ will be helpful
Originally posted by prince with karma: 660 on 2012-06-21
