I'm trying to save the data that my TurtleBot sees when PointCloud2 is turned on. To do this I call 'rostopic echo /camera/depth/points > points.txt' but when I view the data it looks like the following:
header:
seq: 253
stamp:
secs: 1340030655
nsecs: 180170944
frame_id: camera_rgb_optical_frame
height: 480
width: 640
fields:
offset: 0
datatype: 7
count: 1
  • name: y
    offset: 4
    datatype: 7
    count: 1
  • name: z
    offset: 8
    datatype: 7
    count: 1
is_bigendian: False
point_step: 16
row_step: 10240
data: [0, 0, 192, 127, 0, 0, 192, 127, 0, 0, 192, 127, 0, 0, 128, 63,
0, 0, 192, 127, 0, 0, 192, 127, 0, 0, 192, 127, 0, 0, 128, 63,]
Why does it give me the same point over and over again? When the data shows up in rviz it looks perfectly fine...
Originally posted by atmiguel on ROS Answers with karma: 17 on 2012-06-18
rostopic echoing a PointCloud2 will not produce useful output in the data field. What you're seeing is a serialized format which is intended to be deserialized before use. If you want to save point cloud data for later you should use either rosbag record, which you can later play back as ROS messages, or cloud_to_pcd which saves pcd files.
Originally posted by Dan Lazewatsky with karma: 9115 on 2012-06-18
