Hello.
my intention is to control and move a simple robot within the gazebo simulation. i already created the robot model with a urdf file and now i want to move it around. as i understand, the best way to do that, is to create a plugin. i tried to follow step by step the instructions on :
http://ros.org/wiki/simulator_gazebo/Tutorials/GazeboPluginIntro
but when i type "rosmake" I get an error :
/home/daniel/ros_workspace/gazebo_tutorials/src/simple_world_plugin.cpp:1:20: fatal error: gazebo.h: No such file or directory compilation terminated.
I tried to update ROS by typing "sudo apt-get install ros-fuerte-desktop-full" but still, the problem remains.
I am using ROS Fuerte with Ubuntu 12.04.
Is anyone can suggest a better tutorial, or a way to overcome this problem? Thanks.
Originally posted by dmeltz on ROS Answers with karma: 192 on 2012-06-16
Comment by cagatay on 2012-06-17:
have you set your ROS_PACKAGE_PATH correctly ? if not try rospack profile then export ROS_PACKAGE_PATH, that should work
I had the same problem and found that if you include "common/Plugin.hh" instead of "gazebo.h" it will work. My only explanation for why is that the tutorial is a "work in progress."
Originally posted by rctaylor with karma: 36 on 2012-06-18
The intro tutorial was updated. Maybe you can try it again? I managed to complete the hello.world example.
Originally posted by ChengXiang with karma: 201 on 2012-09-10
