I've been having issues when running simultaneously both the Kinect's camera and a secondary (external) USB camera. I have successfully run several cameras together (different drivers and flavors). I am also able to run a kinect without RGB depth registration (so the RGB camera is off) plus other external cameras. However, I can't seem to be able to run both the Kinect RGB camera and an additional USB camera.
Has anyone been successful with this setup: Kinect with RGB registration + Secondary USB camera?
Originally posted by ubuntuslave on ROS Answers with karma: 347 on 2012-06-14
I would gess that this is caused by the high data amount of both devices. The Data is to much for one single USB-Bus (not ports). Try to check which bus the devices are connectet to by $lsusb . Then simply try to connect the devices to different buses. Another idea would be that the webcam is claiming the hole bandwith of to USB-port. Webcams request a whole load of bandwidth, usually more than they need. The uvcvideo kernel module can be set to ignore the requested bandwidth, and to calculate the right bandwidth. Try:
$sudo rmmod uvcvideo
$sudo modprobe uvcvideo quirks=128
This will be reset every reboot. If this works, create the following file:
$sudo vi /etc/modprobe.d/uvcvideo.conf
containing the line:
options uvcvideo quirks=128
reference:
http://comments.gmane.org/gmane.linux.drivers.uvc.devel/5510
https://www.linuxquestions.org/questions/linux-kernel-70/facecam-312-kernel-10-10-conflagration-help-853934/
Originally posted by dinamex with karma: 447 on 2012-06-15
Comment by ubuntuslave on 2012-06-15:
Thanks, the "lsusb" command helped me realize my computer(s) had only 1 USB bus shared among the hubs (even when appearing to be physical apart). The quirks setting did help me with low resolution video and multiple UVC cameras, but still don't know which "mod probe" module applies to the kinect.
