Hi all
I'm trying to compile the sbpl_lattice_planner package from the navigation_experimental Stack, i have installed all the dependencies but the compilation fails.
After checking the log of the compilation it seems that it could not found the sbpl/headers.h header file
Here is a part of the build_output.log,
Scanning dependencies of target rosbuild_premsgsrvgen [ 0%] Built target rosbuild_premsgsrvgen Scanning dependencies of target ROSBUILD_genmsg_py [ 40%] Built target ROSBUILD_genmsg_py Scanning dependencies of target ROSBUILD_genmsg_cpp [ 60%] Built target ROSBUILD_genmsg_cpp Scanning dependencies of target ROSBUILD_genmsg_lisp [ 80%] Built target ROSBUILD_genmsg_lisp Scanning dependencies of target rospack_genmsg [ 80%] Built target rospack_genmsg Scanning dependencies of target rospack_genmsg_all [ 80%] Built target rospack_genmsg_all Scanning dependencies of target rospack_genmsg_libexe [ 80%] Built target rospack_genmsg_libexe Scanning dependencies of target rosbuild_precompile [ 80%] Built target rosbuild_precompile Scanning dependencies of target sbpl_lattice_planner [100%] Building CXX object CMakeFiles/sbpl_lattice_planner.dir/src/sbpl_lattice_planner.o In file included from /home/mario/ros_workspace/navigation_experimental/sbpl_lattice_planner/src/sbpl_lattice_planner.cpp:38: /home/mario/ros_workspace/navigation_experimental/sbpl_lattice_planner/include/sbpl_lattice_planner/sbpl_lattice_planner.h:16:26: error: sbpl/headers.h: No such file or directory In file included from /home/mario/ros_workspace/navigation_experimental/sbpl_lattice_planner/src/sbpl_lattice_planner.cpp:38: /home/mario/ros_workspace/navigation_experimental/sbpl_lattice_planner/include/sbpl_lattice_planner/sbpl_lattice_planner.h:69: error: ISO C++ forbids declaration of ‘SBPLPlanner’ with no type
Any ideas?
thanks a lot
Mario
Originally posted by Mario Garzon on ROS Answers with karma: 802 on 2012-06-13
Hi all
I was able to find the error, it was a matter of the include directories for the sbpl_lattice_planner. I search for the "headers.h" file using the command
$sudo find /opt/ros/ -name "headers.h"
and get as the result:
/opt/ros/fuerte/include/sbpl/sbpl/headers.h
so it seems that this path was not correctly established on the CMakeList.txt file, so i add it to the include directories, just adding this line to the file
include_directories(/opt/ros/fuerte/include/sbpl)
then rebuild the package and now seems to work fine
Regards
Mario
Originally posted by Mario Garzon with karma: 802 on 2012-06-25
Comment by prince on 2012-06-25:
was sbpl included as dependency for sbpl_lattice_planner in manifest.xml?? If yes, manual inclusion for sbpl header directory is not required!
Comment by AHornung on 2012-06-25:
The problem (that I also ran into) is that find_package(sbpl) returns "/opt/ros/fuerte/include/" as include path, which requires all includes to be changed from "sbpl/headers.h" into "sbpl/sbpl/headers.h".
