Hi guys, I run Ubuntu 11.10 plus ROS electric (installed from source) on an Pandaboard ES and try to use a Kinectsensor with this setup. But when I fire up following command
$ roslaunch openni_launch openni.launch I get the following kind of failure:
ERROR: cannot launch node of type [nodelet/nodelet]: Cannot locate node of type [nodelet] in package
I tried to rebuild te packages by rosmake tf && rosmake and now i get a different failure message.
started roslaunch server http://129.73.14.14:53859/
SUMMARY
PARAMETERS * /rosdistro * /camera/driver/rgb_frame_id * /camera/disparity_depth_registered/min_range * /camera/driver/rgb_camera_info_url * /camera/depth_registered/rectify_depth/interpolation * /camera/driver/depth_frame_id * /camera/depth/rectify_depth/interpolation * /camera/disparity_depth/max_range * /rosversion * /camera/driver/device_id
* /camera/driver/depth_camera_info_url
* /camera/disparity_depth/min_range
* /camera/disparity_depth_registered/max_range
NODES
/camera/depth/
rectify_depth (nodelet/nodelet)
metric_rect (nodelet/nodelet)
metric (nodelet/nodelet)
points (nodelet/nodelet)
/camera/rgb/
debayer (nodelet/nodelet)
rectify_mono (nodelet/nodelet)
rectify_color (nodelet/nodelet)
camera_nodelet_manager (nodelet/nodelet)
camera_base_link (tf/static_transform_publisher)
camera_base_link1 (tf/static_transform_publisher)
camera_base_link2 (tf/static_transform_publisher)
camera_base_link3 (tf/static_transform_publisher)
/camera/
driver (nodelet/nodelet)
register_depth_rgb (nodelet/nodelet)
points_xyzrgb_depth_rgb (nodelet/nodelet)
disparity_depth (nodelet/nodelet)
disparity_depth_registered (nodelet/nodelet)
/camera/ir/
rectify_ir (nodelet/nodelet)
auto-starting new master
process[master]: started with pid [11512]
2;/home/panda/ros/openni_kinect/openni_launch/launch/openni.launch http://local1 setting /run_id to 5edfdd6c-b0a2-11e1-856e-2e607c264e01
process[rosout-1]: started with pid [11527]
started core service [/rosout]
process[camera_nodelet_manager-2]: started with pid [11539]
process[camera/driver-3]: started with pid [11540]
process[camera/rgb/debayer-4]: started with pid [11541]
process[camera/rgb/rectify_mono-5]: started with pid [11542]
process[camera/rgb/rectify_color-6]: started with pid [11563]
process[camera/ir/rectify_ir-7]: started with pid [11577]
process[camera/depth/rectify_depth-8]: started with pid [11590]
process[camera/depth/metric_rect-9]: started with pid [11606]
process[camera/depth/metric-10]: started with pid [11622]
process[camera/depth/points-11]: started with pid [11634]
process[camera/register_depth_rgb-12]: started with pid [11647]
process[camera/depth_registered/rectify_depth-13]: started with pid [11667]
process[camera/depth_registered/metric_rect-14]: started with pid [11681]
process[camera/depth_registered/metric-15]: started with pid [11708]
process[camera/points_xyzrgb_depth_rgb-16]: started with pid [11723]
process[camera/disparity_depth-17]: started with pid [11736]
process[camera/disparity_depth_registered-18]: started with pid [11750]
[camera/rgb/rectify_color-6] process has died [pid 11563, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-rgbg [camera/rgb/debayer-4] process has died [pid 11541, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-rgbg [camera/ir/rectify_ir-7] process has died [pid 11577, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-ir-g process[camera_base_link-19]: started with pid [11774]
process[camera_base_link1-20]: started with pid [11791]
[camera/driver-3] process has died [pid 11540, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-drig [camera/depth/points-11] process has died [pid 11634, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depg process[camera_base_link2-21]: started with pid [11806]
[camera/depth/metric_rect-9] process has died [pid 11606, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depg process[camera_base_link3-22]: started with pid [11827]
[camera/register_depth_rgb-12] process has died [pid 11647, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-regg [camera/depth/rectify_depth-8] process has died [pid 11590, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depg [camera/depth_registered/metric-15] process has died [pid 11708, exit code 255]. log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depg [camera/points_xyzrgb_depth_rgb-16] process has died [pid 11723, exit code 255]. log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-poig [camera/depth_registered/rectify_depth-13] process has died [pid 11667, exit co. log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depg [camera/disparity_depth-17] process has died [pid 11736, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-disg [camera/disparity_depth_registered-18] process has died [pid 11750, exit code 2. log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-disg [camera/rgb/rectify_mono-5] process has died [pid 11542, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-rgbg [camera/depth/metric-10] process has died [pid 11622, exit code 255].
log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depg [camera/depth_registered/metric_rect-14] process has died [pid 11681, exit code. log files: /home/panda/.ros/log/5edfdd6c-b0a2-11e1-856e-2e607c264e01/camera-depgBlockquoteBlockquote
This is the output for
$ openni_camera openni_node.launch
process[master]: started with pid [980]
2;/home/panda/ros/openni_kinect/openni_camera/launch/openni_node.launch http://1 setting /run_id to 52bb505c-af53-11e1-8307-4b990ca55b67
process[rosout-1]: started with pid [995]
ERROR [1338930820.996429071]: Couldn't find a preferred IP via the getifaddrs. ERROR: cannot launch node of type [openni_camera/openni_node]: Cannot locate no] process[kinect_base_link-3]: started with pid [1007]
ERROR [1338930821.167174922]: Couldn't find a preferred IP via the getifaddrs. process[kinect_base_link1-4]: started with pid [1008]
ERROR [1338930821.278625116]: Couldn't find a preferred IP via the getifaddrs. process[kinect_base_link2-5]: started with pid [1020]
ERROR [1338930821.386413202]: Couldn't find a preferred IP via the getifaddrs. process[kinect_base_link3-6]: started with pid [1031]
ERROR [1338930821.468139277]: Couldn't find a preferred IP via the getifaddrs.
Would be great to get some help. Cheers
Originally posted by dinamex on ROS Answers with karma: 447 on 2012-06-05
Comment by Martin Peris on 2012-06-05:
Are you sure that the packages "nodelet" and "tf" are properly installed? You can check for example: rospack find nodelet. It should return something like /opt/ros/electric/stacks/nodelet_core/nodelet.
Comment by dinamex on 2012-06-06:
Thank you for your comment. I checked if they are installed with rospack find nodelet (result : /home/panda/ros/nodelet_core/nodelet) and rospack find tf (result: /home/panda/ros/geometry/tf )
the different path is probably caused by the installation from source.
Comment by Martin Peris on 2012-06-06:
If you installed from source, the error messages make me suspect that the binaries for nodelet and static_transform_publisher are not built. Have you tried rosmake tf && rosmake nodelet ?
