Hi,
Is there a simple way to store change of ROS_MASTER_URI? So when ever I boot up my machine (or start node) this would always be changed to for example:
export ROS_MASTER_URI=http://ubuntu:11311
Now it changes always back to default
$ echo $ROS_MASTER_URI
http://localhost:11311
Originally posted by ajr_ on ROS Answers with karma: 97 on 2012-06-04
Yes - add a line to your ~/.bashrc (assuming you're using bash)
If it's in your ~/.bashrc, it'll be exported every time you open up a new terminal. If you want edits to this file to take effect in your current terminal, type:
source ~/.basrhc
Originally posted by lindzey with karma: 1780 on 2012-06-04
Post score: 4
Comment by Thomas on 2012-06-04:
Nitpicking: assuming you're using Bash, not Ubuntu ;) (type "echo $0" to know your shell, Bash by default under Ubuntu)
Comment by lindzey on 2012-06-05:
@Thomas - Thanks! Edited to include your correction....
