Hello,
Is there a ropsy scheduler for calling a function after a period of time (or periodically calling it every n secs). The python sched module is kind of misbehaving, I guess it conflicts with ros based on the following example using the ps joystick with the PR2:
#!/usr/bin/env python
import roslib; roslib.load_manifest('d3')
import rospy
import sched, time
from sensor_msgs.msg import Joy
class Joystick(object):
    def __init__(self, topic_name='/joy'):
        self.topic_name = topic_name
        self.buttons_names = {'l1':10, 'l2':8}
        self.sub = rospy.Subscriber(topic_name, Joy, self.cb)
        self.blocked = False
        self.sched = sched.scheduler(time.time, time.sleep)
        print '>>> press L1 button'
    def cb(self, data):
        print '>> in callback:', data.buttons[self.buttons_names['l1']], data.buttons[self.buttons_names['l2']]
        if not self.blocked:
            self.foo(data)
    def foo(self, data):
        print '>> in foo:', data.buttons[self.buttons_names['l1']], data.buttons[self.buttons_names['l2']]
        if data.buttons[self.buttons_names['l1']]:
            self.blocked = True
            rospy.loginfo('%d', data.buttons[self.buttons_names['l1']])
            rospy.loginfo('L1 pressed')
            self.sched.enter(1, 1, self.bar, ())
        self.sched.run()
    def bar(self):
        rospy.loginfo('resuming control')
if __name__=='__main__':
    rospy.init_node('foo', anonymous=False)
    joy = Joystick()
    rospy.spin()
Thanks!
Originally posted by Yianni on ROS Answers with karma: 123 on 2012-06-01
A Timer should do what you want.
Originally posted by Dan Lazewatsky with karma: 9115 on 2012-06-01
Comment by Yianni on 2012-06-01:
Thanks. Works like a charm.
