Hi,
I'm writing a launch file and I want to pass a package name as an argument. The launch file should then look for the appropriate package. I wrote the following:
<arg name="robot" default="mh5_mesh" />
<include file="$(find $(arg robot) ... />
But when I run this, roslaunch complains: Dollar signs '$' cannot be inside of substitution args
Is there any way around this? How else can I pass a variable to $(find)? Is there some other method I should be using?
Thanks!
Originally posted by somudrog on ROS Answers with karma: 55 on 2012-05-30
Comment by Procópio on 2019-07-11:
I updated the correct answer as there has been new solutions developed since this question has been asked.
3 Answers 3
A solution to this problem has been added to roslaunch version 1.12.1, released on April 18, 2016. (ATM the debian repos are at version 1.12.0, so you'll either have to wait or download the github sources)
roslaunch 1.12.1 adds support for evaluation of arbitrary python expressions using the syntax $(eval <expression>). With this change, the following is possible:
<include file="$(eval find(arg('robot')) + '...')"/>
args are available as python variables, so the following is equivalent:
<include file="$(eval find(robot) + '...')"/>
Originally posted by juztamau5 with karma: 86 on 2016-06-03
Post score: 6
I cannot see an easy solution to your problem. I recommend supplying the absolute path of the file at command line. For instace:
roslaunch package file.launch robot:=`rospack find package_2`/relative/path/to/file
And using it directly as $(arg robot) in your launch file.
Depending on your exact application, there might be a better solution.
Originally posted by piyushk with karma: 2871 on 2012-05-31
In case someone is stuck with older versions of roslaunch due to other dependencies, here is a workaround:
<arg name="path"   value="(find $(arg robot)...)" />
<arg name="dollar" value="$" />
<include file="$(arg dollar)$(arg path)"  />
In my case I needed it to call the appropriate moveit_config file based on the robot and this hack works fine on ROS indigo
Post score: 4
Comment by wsneijers on 2018-01-23:
Thanks for this genius solution! Also i can confirm it working on ros kinetic.
