I use Ubuntu 11.10 and I try to communicate to a Kinect sensor (the kinect is connected). I followed the instruction from http://www.ros.org/wiki/openni_kinect and get some problems.
cd openni && make
make[1]:Entering directory '/root/drivers/openni'
git clone https://github.com/OpenNI/OpenNI.git build/openni
Cloning into build/openni...
remote: Counting objects: 4866, done.
remote: Compressing objects: 100% (2064/2064), done.
fatal: The remote end hung up unexpectedly MiB | 1 kiB/s
fatal: early EOF
fatal: index-pack failed
make[1]: ***[build/openni] Error 128
make[1]: Leaving directory '/root/drivers/openni'
make: *** [openni_lib] Error 2
Originally posted by rosmaker on ROS Answers with karma: 51 on 2012-05-29
That looks like GitHub had a hiccup or your network connection. It should work when the issues is resolved. And as @Mac says it's recommended to use the binary installs when possible.
Originally posted by tfoote with karma: 58457 on 2012-05-30
I'd suggest installing them from binaries instead: apt-get install ros-fuerte-openni-kinect
Also, when you are building parts of ROS from source, you shouldn't do it as root.
Originally posted by Mac with karma: 4119 on 2012-05-29
Comment by MarkyMark2012 on 2012-05-30:
is this avaliable for debian - I'm getting an error unable to locate package? - Thanks M
Comment by Mac on 2012-05-31:
For actually-Debian, not Ubuntu?
Comment by MarkyMark2012 on 2012-05-31:
Debian:squeeze specifically
Comment by Mac on 2012-06-01:
So far as I know, .debs are only built for Ubuntu, so a source install is the way to go. I like @tfoote's idea that this is a github hiccup, and you should try again (see also: don't build ROS nodes as root).
